Galaxy S6 : Post Pictures Of Your Home Screen(s)
It looks like the once that are in the play store appear to be like the metro type of icon pack for windows 8, and if there is one out there you might have to root it. Sorry couldn't help.
Here is one of mine that I set up. I'm pleased with the results.
Have you used Zooper widget before? It might the only way right now that you might be able to get windows icons. You would have to find pictures online of the icons you want and then make your own icons using Zooper. It might be a lot of work though, lol! But it'll probably be the only way to get them right now
I do have Zooper. Don't have the patience to do that though. I'll keep hunting for the icons. Someday I'll find some. 😉
One can only hope! LOL!
It's too bad you're not using Nova on your S6, because I would make you the MS icons as PNG files that you could use.
Now, I don't know if this exists ... but if there is a "stand-alone" app that you can install that lets you customize your app icons individually, then you'd be able to use the icons I can make you.
Just let me know if you want a set of the MS app icons ... and specifically which ones.
EDIT TO ADD: Also, if you want them, do you want them "square", or "cut-out" of the square mold and transparent around the outside? If you were using a black screen background, this is what the two styles would look like ... on the left is the "cut out", and on the right is the "square"...
With everyone using nova, I'm curious to know what base theme is everyone using? I'm talking about the ones from the Samsung theme store.
For my set up, I'm using the "urban theme."
Re: Post Pictures Of Your Home Screen(s)
Home Screen on my Galaxy S6 using Nova Prime Launcher
fulapmu2
