Galaxy S6 USB connection trouble with Windows 10
All you need to do with new windows 10 not detecting Android phone is, install below two KBs and restart.
Step1. install: 'KB3010081' ---> https://support.microsoft.com/en-us/kb/3010081
Restart
Step 2. install: 'KB3099229'---> https://support.microsoft.com/en-us/kb/3099229
Restart
And you are done. Open My computer and you will see MTP logical drive in there.
After one more reboot, you may see your phone model/ make as drive label.
Thanks and enjoy!
Rupesh Diwaker
I had the same problem on windows 10.
I try using to put the cable in the 2.0 usb and it did work fine with me.
It was connecting all the time i was going mad.
Now i can see my galaxy s6 in the Computer screen.:cool::cool:
You are so spot on. After many different avenues, downloads etc, I read your comment, changed the cable and hey presto.....connected.
I'm running in to this problem too. Even with developer options enabled I can't get the computer to recognize my phone. I talked to Samsung's technical support this morning and they suggested doing a factory reset. Of course that means losing everything. I do have my photos backed up to Google photos, but would really prefer to not have to re-download certain pictures, documents, etc.
When I first got the phone, I had no problems and thinking about it, I'm wondering if the problem started when the 6.01 updated was installed? Perhaps when Nougat is pushed to the phone it'll resolve problem.
Try this
General News & Discussion
Fix Galaxy USB driver update problem following Windows 10 Upgrade
Started by Resolver, 05-24-2017
TheGreatApe00
