[Gear S2 Owners] Show Your Straps
Thanks. I will check it out, how did you order it? and once you got the adaptor you can use any of the Classic bands? Yours looks great.
Got the adaptor on the site from Germany got it in one week... Band I got from Amazon comes with the quick release pins. Changing bands is easier than stock OEM sports straps for me now. Yeah my nails get in the way.:mad:
I got the adapter from Germany. It said that it was for the 720 "Sport" model, but it works just fine on my 730. The dark gray matches the color of the watch perfectly.
My only problem is finding new watch bands that are small enough to fit my wrist!
The Milanese loop magnetic band will fit just about anyone no matter how big or small if you into the leather look they have some of those with the magnetic loop on those as well all found on amazon.
All of the watchband pics posted thus far appear to have straight ends where the band meets the watch in the adapters (as does mine). I am not satisfied with this and would like to find a band with curved ends so that there is minimal gap between band and adapter interface.
Anyone have any luck finding a suitable band similar to the second band in post #4 with curved ends?
$2 Nato strap from eBay! I love it.
(i'm female. not sure where my avatar went to. lol)
TheGreatApe00
