Get out of contract.
I'm going to write an email to sprint, and see what they tell me. It's very saddening that they would treat customers this way.
It's free to get out of your contract actually, just run your roaming data up enough and they'll cut you off no etf.
Sent from my SPH-L710 using Tapatalk 2
So I installed the 00001 prl and constantly check netmonitor to make sure im on a Verizon tower, I am so I should be roaming right? Over the last 2 days I've been on pandora, Netflix and YouTube. The usage monitor built into ICS says I've used 400mb over the last 2 days but the sprint website says I haven't used anything since the custom prl, what gives?
And roughly how long should it take sprint to notice my new found roaming habit?
My friend had sprint and he was having the same problems, he told them that he talked to a lawyer(he didnt though) and stated that sence he is having these problems and they are constant that he should have to wait for and he should be able to switch with no contract problems
Load a verzion prl and use that constantly till sprint ask you to take your service elsewhere use a lot of data and you will be off in a month or have good speeds till they kick you off
I've been doing that for 3 month and they keep putting on bill to "see data terms" but havnt received the letter yet
Sent from my EVO using Tapatalk 4 Beta
2009sxs
