Gingerbread is here.
Downloaded and installed about 2 hours ago. Everything seems very speedy. Haven't been able to test voicemail issue. Attempting to get someone to call me right now.
I need to install this soon my data connection drops all the time. I got that file downloaded you posted adrynalyne but I'm guessing a need to flash a radio also
You can get the radio here
Whatever you do, don't flash the RUU if you are rooted, as this will cause issues. If you want to be on the most recent update, I'd recommend looking at some custom ROMs around here or at Rootzwiki.
Adrynalyne posted a zip file for this, is that what your reffering to? I am rooted also. So if I flash the radio then that file he posted i will run into trouble
I wasn't sure what Adrynalyne posted. He knows a ton more than me, so he's definitely a good guy to trust, but without knowing the file he posted, I wanted to give you the warning to be careful what you flash.
There is a stock leak of the GB update that's floating around, and if you flash that, it'll cause issues since you are already rooted. There are also pre-rooted versions around, that will be fine to flash. Then, there are radios, which seems like the top priority for you at the moment.
With all of them, you should be sure you check the MD5 before flashing, and be sure you know what you are flashing before you do. With all the new releases recently, the key is to double and triple check before you do flash, and of course, if you have any questions, read around the forums and ask!
For those of you that were frustrated with Swype not working correctly with the HTC messenger and mail apps, those appear to have been fixed with this update. Hooray!!! :D
people actually use those? messenger is terrible compared to gosms. like not even usable to me after spending 5 months with gosms.
He said its the leaked one and its pre rooted too. I downloaded it already and its on the root of my SD card waiting to flash in clockwork. Can I install the radio you linked then flash the pre rooted gb leak zip file i got from adrynalyne?
His post with the link is on page 19. It sucks buying a phone that's not up to date im trying to play catch up thanks for the help
Yeah I just installed the radio and it went thru I'm gonna flash that zip you linked me now. I know how to flash the stuff I just didn't know what files went together. Be back in a minute and let you know if this file you linked goes thru
It's kind of funny to read all the rooters (that were laughing at us non-rooters) trying to figure out how to get their phones working right again.......sorry guys, but I guess the humor is only one sided. ;)
Reactions: Devils Advocate
I downloaded the update around 1pm central time. Took about 20-30min. I love the changes personal, the phone is moving much faster, front facing camera for skype is working, love the new catergorized apps(all,frequent,downloaded and verizon), love the new notifications menu (notifications and quick settings), facebook seems to be running a whole lot better, battery seems to be decent(still not the best). I know there were more changes, and I will check it out later today and report my findings. :)
Lol thanks adrynalyne flashed the radio and your file and I'm all good up and running now
People who used the leaked RUU are not necessarily rooted. Big difference. If you were rooted then you would be using something like Bamf Forever which is WAY better than the OTA. The people having trouble are non rooted users that are using an older ruu (like 605.0) and want to upgrade to 605.3. Adr has suggested that .3 might be considered a downgrade from .0.
Reactions: Adrynalyne
so us rooted people have already had this for a while it's just that this is official? and once the devs get there hands on this our roms will be mush better? correct? lol
I have a patch that will update 2.11.605, or 2.11.605.2, to 2.11.605.3 on teambamf.net.
It consists of:
Camera library updates (Which break google talk video)
Updates to logging applications for troubleshooting.
HTC Mail (in the form of Exchange)
HTC Footprints.
RIL library Updates (that appear to do nothing)
If that excites you, head on over and grab it.
Not meant for custom ROMs. All recent BAMF versions have a patch ready,
I compared framework by decompiling. I compared apps by decompiling. I did a binary compare on bins and libs.
Volume down + power = nothing???? Running 2.07.605.0 RUU
I would like to update to current but I can't get into recovery screen. Any suggestions???
BTW not rooted.
mostafamu
