Gingerbread Leaked Software Issues
What Leaked Software Do You Have?
  • Total voters
  • Poll closed .
To those of you complaining of bad battery, connection speed or stability issues or GPS issues . Are you running the latest radio leak, I think the battery improvement is largely due to the new radio, I am running the newest radio and I haven't seen a single one of these issues, only camera force close and no voicemail notification
I did a reboot and now Google Talk force closes and camera opens a black screen that fades to home screen..... very odd
I'm not sure why changing the date fixes this, but it does.... I had thought Google Voice update was to blame.... Seems this is GB error.
Sent from my ADR6400L using Tapatalk
Finally hit LTE speeds I haven't seen seen since loading RUUs (2.07 and 2.11). Better yet it was the farthest south of the Ohio River I've seen. 16/2 isn't the fastest I've seen, but it was it good to see new radios weren't throttling. Just poor LTE coverage in my travels.
Running the 2.11 RUU
Issues:
-Slow fade/ghosting icons in status bar.
-Camera bug (fixed by changing date to 8/1/2011)
Other than that, smooth as silk and much fast than the stock froyo
I'm on 2.11 and used 2.07. While on Froyo I was hitting an average of 25/6 and now its more like 10/2... and I am in perfect LTE coverage all the time. I suspect they might have lowered the voltage to the LTE radio slightly, or there is a deliberate limiter in order to help with future customer expansion. The latter would be a VZW request, and I would think they would have told my department about that, but you never know.
Can I get some speed test examples from other people running leaked GB versions? It would also be helpful if you can also cite what your were getting on Froyo MR2.
I'm on 2.11 as well. My speeds are all over the place. I've seen close to 20 up and 6 down but my average is closer to 10 down and 3-4 up. I used to get 20-25 down, and around 6-7 up on Froyo.
Froyo I normally saw 16/7 max 25/8 worst 6/4. Since 2.07 and 2.11 normal has been 4/2 max 16/2 worst 4/1.
on froyo, I was seeing form 10 d /1 u to 18 d/ 1 u, and I am seeing the same now...
*edit I am running 2.07
Miserydhala
