Gingeritis 3D 1.07 is out and awesome!!!!!
I switched today to give Gingeritis a try. So, far, I am impressed. I am restoring my apps via MyBackUp Pro and it is restoring them I think 2X faster than BAMF Forever.
Anyone else notice this?
I have been on bamf forever for a long time... and decided to give Gingeritis a whirll..... I AM FREAKING BLOWN AWAY... this rom is so much smoother.... I will post back later about the battery life....
Just added latest ziggy. Sucker is major responsive.
But be advised - lock up and other quirks might show up w/ any new kernel.
Is that ziggies Sept 13 kernel. I've been running this one for about a week and its been doing great..
Sent from my ADR6400L using Tapatalk
Battery life is much better than Forever, especially with Ziggy's Sept. 13 kernel. G3D also seems a bit smoother on my Bolt. I love Forever, it was my favorite ROM... And at first I still liked it better than G3D, but after abusing this ROM for a few days I have a new daily driver.
I tried Ziggy's 11/5 test kernel. Very fast, but I couldn't change any frequency or governor settings. I can't wait till the final release.
Im using AnTuTu CPU Master Free v 2.1 and i'm able to change the CPU freg and scaling without a problem.
Is there a way to add Airplane Mode into the quick settings drop down menu??
I'll check out AnTuTu... ROM Toolbox wasn't allowing any changes, but it works fine with the Sept 13 kernel.
must have been a bad flash. Reflashed Ziggy's 11/5 and ROM Toolbox works perfectly... This kernel is smokin'
Do you suggest any special way of installing this new ROM? I've flashed back and forth between roms several times, both via ROM Manager and also manually via recovery, but i've tried installing this one 3 times using each method and it will not finish the installation. So now, i've wiped everything 6 different times while trying to install this ROM and have gotten nowhere. Ideas?
I'm currently running BAMF Forever 1.0.8/1.0.9 with the imoseyon 4.1.3GB test kernel.
That's what I thought. But I downloaded it 3 different times. Each new time i downloaded it, i deleted the old download first. I'm trying to do it through Dolphin HD but it goes through the whole download so i didn't think anything of it. Should i instead do it via the computer and move to my SD card?
getting the same thing...flash fails with 'E:Can't open "the file name.zip" (bad)' have tried twice. I figure it is just a bad download, but not sure where else to get it. I do wonder if it is a problem created by downloading through Dolphin. I am just downloading with the phone then moving to root on card. Maybe I will try tonight downloading with computer and then transfering to my phone. See if that makes a difference. Anyone else have experience in this? I did not see an answer to above question.
Thanks
It would be sweet if you could download this to your phone directly. I guess I could install the thunderbolt drivers on my pc but it would be nice to be able to just download it directly.
Well, I rooted last month, and just flashed Gingeritis yesterday. So far, I like it. It's allot like stock, but snappier and more fluid.
Thanks
From TheMikmik page.
"If you are having problems downloading files, please try using Opera Mobile or Firefox until a permanent fix can be found. Thank you."
I assume this means there have been issue with downloading for other browsers. Including DolphinHD. Just a guess though.
No members online now.
Dreamz
