Goodlock is awesome.
This app is AMAZE BALLS!! loving the dark notification shade and transparent notifications. been waiting for this since forever.
Playing with it now, thanks. What's different in the ClockFace compared to stock? Options look the same.
You need to go all the way to the right and select that one and another screen will open up with many clock faces for lockscreen and AOD.
I didnt see this one stock
This app is the shiz!
Samsung should have baked these features into TouchWiz by default.
If they had baked it in, ppl would complain that they didn't have the option of getting rid of it. Like Bixby for example. Can't please everyone
I downloaded it but it was Goodlock 2018, totally took over my phone and i couldn't work anything, had to uninstall. is that the one?
I use the heck out of the task changer. reminds me a little of bb10 and makes closing and switching apps much easier
I will get into it more here in the near future. So far the big thing I LOVE is that the darned pull down screen isnt white anymore
It's a great partner to Nova. Now I'm able to truly personalize my phone by theme, launcher, and pull down shade.
My Halloween theme is ROCKING!
I've been using Good Lock since it was first introduced , its awesome!!
I like making my drop down menu shade dark and enable my notifications in white
Here is my quick settings
I don't know but I've been trying to get Edge lighting to work and I can't seem to get it to work. Anybody have any suggestions
Did you go into the edge lighting settings and choose what apps you want ? I only have mine set for messages. It automatically sets it for calls when you turn it on. the lighting for calls only seems to work when I have the phone face down, but with my messages it works face up. Screenshot_20180930-083816_Edge%20screen.jpg
vigorific
