Google Maps
Re: Google maps voice commands
There's a new Google Maps widget called "Google Maps Driving Mode". It cuts out a lot of the unnecessary prompts and gets you straight to finding and navigating to a destination. Long-press a blank space on your Home screen and go to Widgets and it's there under Google Maps. Drag it to your home screen and give it a try!
I also like the Google Now set to allow "OK Google" everywhere. :)
Thanks.
Smartphone, Samsung Galaxy S5, Lollipop 5.0, Verizon network
Re: Alternate route in Google maps
I want to show alternate route as like in google maps ,when we search for direction google map will give us alternative route in gray color...
but I am unable to activate that attribute of direction api...if you found any reference please tell me....
thanks
I am totally frustrated by not having alternative routes or the ability to change. Right now i know that i have to use an alternate freeway because there is a race winding through streets around me. Even several freeways are being used. Many streets (and parts of the 2 freeways also) are closed, or only have traffic one way (the opposite way i need), or are crowded with racers, joggers, walkers, and all the watchers and sponsors of the event.
Google maps doesn't recognize these street closures and one-way changes. And i can't find any way to choose the roads i need. So maddening and frustrating!!
Google maps not working
Is anyone else having a problem getting Google maps to load?
Google maps not accessible
Am I the only one in the country that can't access Google maps. It worked 2 hours ago. Thanks.
Anyone with S5 having problem with Google maps?
I find it hard to believe that I'm the only one with a Google maps problem. If anyone is using Google maps without a problem, please let me know. Thanks.
re: Anyone with S5 having problem with Google maps?
What problems are you having exactly? It's my go-to navigation, zero problems.
Android Central App | S5 G900A kitkat root
It won't load. I get a network error both with WiFi and network data. All other apps work fine. It worked several hours ago. If anyone can try their application to see if your's work. I've never had a problem with Google maps for the 2 years I've used it. Any suggestions would be appreciated. Thanks.
No issues here.
Google Maps v9.21.0
S5 on Verizon
Roseville CA
Clear the cache and partition cache.
No issues here.
Google Maps v9.21.0
S5 on Verizon
Roseville CA
Thanks for your help. I have the same version and tried both of your suggestions. Neither worked. I'm very frustrated. Any other ideas.?
Re: Google maps not accessible
You might be... I don't have any problem with Maps or Nav here in Hawaii.
Have you updated the Maps app or OS since this issue? Uninstalling updates and reverting the app back to its factory version may fix it.
I had faced this issue once. The only thing that worked for me was going to my list of applications->Maps->Clear Data->Uninstall updates.
After this I went to the store and updated the maps app. It worked after that.
Re: Anyone with S5 having problem with Google maps?
Tried it and it doesn't work. Nothing I've tried works. I'm at my wits end. Here is the screenshot.
Just checked my Maps, worked fine, have you tried Waze? it is a pretty good map/direction app too.
Verizon S5
RU2BPB1 version
2016-02-01 security patch
doublemint
