Google Nexus 6 on T-Mobile
Re: T-mobile has them on the floor
If you go into it knowing the display/battery/camera is better on the Note 4, it makes the decision easier. I think you can definitively say the Note 4 is the better device overall, but having pure Android on the Nexus 6 is going to be enough for some people to make that sacrifice.
Oh I personally think it's better hardware wise but I'm semi interested in Stock Android
Sent from my SM-N910V using Tapatalk
Actually found a store with the phone on the floor and played with it for about 15-20 minutes. Basically, if you're worried about the camera in the slightest, I wouldn't be. Without HDR mode on, it took pictures instantaneously with no trouble and they looked great. With HDR on, it was about a full second delay until the picture was done being taken. Honestly, comparing the pics I took, I would keep HDR off for normal, off-the-cuff pictures you're taking that don't need to be as beautiful as possible and you'll be fine. The HDR did obviously make it look better, and I couldn't move the phone far off it's holder to try different kinds of pictures of different spots of the store, but only slightly to my eye. It isn't 100% necessary and you should be fine without it. Just save it for more important times where the photo really matters and you'll be set.
And to whomever was asking about taking a bunch of pictures then going to the gallery to see if it lags on loading, the unit I used pulled up the gallery no problems. However, if I tried doing a quick swipe through a bunch of the photos there was a noticeable amount of lag, but it was very slight for me. I forgot to check if there was an option to look at photos in the gallery through a column/row set-up, but if there was, that's what I would probably be using and at that point I couldn't see lag being a problem.
As far as screen goes, sadly the criticisms about the screen brightness do have merit to them. My HTC EVO 4G LTE has a brighter screen with both at max brightness and auto-brightness turned off, but there was never a time where it wasn't bright enough for me and it was something that I couldn't use. Also, it does seem not as vivid, but I think these are things that will be most readily apparent if you're doing a direct screen comparison with another phone right next to you. Once I was spending time just with the N6 my eyes stopped noticing the differences it had been a few minutes ago and I was just in awe of how big of a phone this really is.
Transitions within apps and the app drawer were 100% smooth as everybody else has commented on. The back did pick up a little bit of smudging/finger-print grease, but honestly not as bad as what I've heard (coming from an EVO I've dealt with much more noticeable marks on the back haha). Also if you're like me and weren't a big fan of the powder blue trim around the phone, it honestly looks much better than I expected and is much more subtle than some of the pictures of the phone that I've seen so don't worry about that. The speakers are strong and I didn't even put them at 100% due to interrupting the rest of the people in the store nearby me, but they should be more than enough for every person who lists that as something important and is okay with one step below Boomsound.
I'll update this if I remember more things, but like I said the main thing you'll really notice is how big this phone is. In my opinion the Note 4 really does have a nicer look to it design wise, but I'm won over with the Nexus and real excited to hopefully pick it up from Sprint tomorrow. Also I was not expecting the Nexus to be as thin as it is, and am honestly very happy I have a Spigen Neo-Hybrid coming in to help it feel more substantial. The only other thing I can think of is that I couldn't get a normal hold on the phone due to the security tether, but I wouldn't be surprised if it was a little bit slippery as well. Hope this helps some of you guys out, and if you're on the fence between a Note or a Nexus, my opinion would be that at this point there's really no way to wrong and seeing it at the store really confirmed that for me.
Edit: An important last note is that within the notification drawer it was asking me to do an update to Lollipop, so any stutters from the gallery or HDR could actually be less than what I saw.
My issues with the camera isn't that it doesn't take great pictures which it does. My issue is.... Is it better then my note 4. I think the note 4 is better camera.
I went to T-Mobile for a second time to checkout the Nexus 6. The phone was still not out on display so the manager had to go to the back to get the phone for me. The manager had the Note 4 as his personal phone so I was able to put both phones side by side, honestly the Note 4's display is noticeably better then the Nexus 6. Colors on the Note 4's display looked more rich, vivid, and sharp compared to the Nexus 6. The Nexus 6 has a maximum brightness of 270 nits compared to the Note 4's display that has a maximum brightness of 468 nits. The screen brightness of the Nexus 6 seriously holds it back in my opinion. I did the same by putting the Nexus 6 next to the iPhone 6/6+ and came to the same conclusion. The manager and I ended up putting the Note 4 and the Nexus 6 side by side to take a picture (both phones used the google camera app). Both phones were fast to take pictures, the quality of the pictures looked good on both phones, I did notice that the colors were more accurate on the Nexus 6, but the Note 4 had more detail when zooming into an object in the photo (probably because the Note 4 has a 16mp rear camera compared to the 13mp rear camera on the Nexus 6). I was able to test out HDR+ this time around, its true that HDR+ takes awhile to process. Clicking the HDR+ mode on the Nexus 6 takes a second to load, after taking a picture with HDR+ the Nexus 6 takes 1-2 seconds to process the photo until you are able to take another photo, and if you swipe left to see that HDR+ photo then the phone needs another 1-2 seconds to finish processing the HDR+ photo. I'm not going to lie, this seriously has made me second guess whether I will be keeping this phone or returning it to go back to the Note 4 or to the iPhone 6/6+, only time will tell....
I like the Google camera app besides the fact it doesnt save to sd card
The comparison reviews of pictures taken from the Note vs the Nexus make the differences really seem negligible, with the Nexus 6 being more true to color and less over-exposed than the Note, while the Note gets better detail but even then that's been for things in the background that you notice when you zoom in. It looks like better low light from the one reference they did, too.
Okay so it seems that the maximum brightness of the Droid Turbo got better after it got a system update. Hopefully they do the same for the Nexus 6 because the maximum brightness seriously needs to be increased.
Eh while it might get better if screen brightness is a big factor I think note 4 wins. The nexus 6 screen looks like note 3 or s4 ish Imo as far as color accuracy and brightness
Eh I've seen that and discredit that site.. Seen pics from the verge that look much better. Also from Engadget
I've like the detail and color on auto and liked the other features
If your concern is to have the best camera, you don't get the Nexus 6. That's both in image quality and user experience. If your concern is to have the best battery life, you don't get the Nexus 6. If you want the best display, you don't get the Nexus 6. If you want an SD card and a removable battery, you don't get the Nexus 6.
You keep mentioning the 6 inch screen---take the on screen buttons into account and it's probably smaller than the Note. You keep mentioning the "world class cell radios", but that's just based on prior history with Moto. There's been a few reviews, most notably on this site with Phil and Jerry, that say the radios weren't as strong as other devices. That's been a Nexus issue before. Build quality is great. No denying that one, but it's not anything I'd say tops the M8, iPhone 6, or even the Note now that it has a metal frame with chamfered edges. You can't even use the thing on a flat surface without it wobbling all over the place.
Simply put, and I'm sorry to be the one to have to tell you this, but you're not getting the best phone available. You're getting the best phone available for YOU because it's your preference. Unfortunately you're a tad bit too into this phone to acknowledge it's shortcomings.
I again disagree with a number of your assertions. For example, depends what aspects of camera image are important to you. Low light without flash, yes, absolutely there are better camera phones but not necessarily for other aspects.
Software buttons often disappear depending on what you are doing etc.
The biggest points I believe you are missing is that most people don't make a decision based on one aspect of a camera or exclusively on any one aspect of a phone and that "better" in some aspect does not necessarily mean it will even be noticeable.
Yes, the screen is *only* measured to put out 278 nits max but if you are rarely going to use it past 60% brightness and that is ideal for you who cares?
People just need to play with the phone in person and ignore 95% of the dribble on these forums. I am not biased towards any manufacturer as I have owned iPhones and the Note series and coming from the Note 2 the Nexus 6 is the only phone I am considering upgrading to not because " I am too into the phone" but because I have bedn rationally evaluating all the options...
Ya know what I want to know about a camera comparison. If the one doing the comparison took 15 photos and picked the top 5 or took 5 photos and how they look is how they look. What's the methodology in their comparison? There's no doubt some of these phones CAN take a good shot. But how many takes does it require? There's one thing the iPhone has over all phones, it CONSISTENTLY takes quality pics.
You the biggest points I believe you are missing is that most people don't make a decision based on one aspect of a camera or exclusively on any one aspect of a phone and that "better" in some aspect does not necessarily mean it will even be noticeable.
People just need to play with the phone in person and ignore 95% of the dribble on these forums. I am not biased towards any manufacturer as I have owned iPhones and the Note series and coming from the Note 2 the Nexus 6 is the only phone I am considering upgrading to not because " I am too into yne phone" but because I have bedn rationally evaluating all the options...
Thus guy is haliarous.... Says he's rational but isn't..... Its his way or the highway.
I think the Nexus 6 and Note 4 both take good pictures. The Nexus 6 photos look as good as the Note 4 but the Nexus 6 in my opinion wins in color accuracy. However, the Note 4 takes better low light shots and has more detail when you zoom into a photo.
I liked the iPhone 6 plus but the few shots I took at a bestbuy store I didn't quite liked them. My opinion is note 4 > nexus 6 > iPhone 6 plus
I like the Google camera app as well because its simple and quick to use like the camera app for the iPhone 6/6+.
I don't care about the colors accuracy difference because it's not huge of a difference to care. I liked the low light shots way better and detail in general is better on the note 4.
I like the Google app but prefer the Samsung one because I can save to sd card. If the Google camera app can save to sd card I would use that instead
Its obvious our opinions differ on what we consider important on a phones camera lol. I will agree that I like the low light shots on the Note 4 better then the Nexus 6 but I don't care how much more detail the Note 4 has over the Nexus 6 because you can only tell if you zoom into a photo.
Yeah....the word "rational" doesn't quite describe it. I'll let you believe what you want to believe.
Yeah it's really a matter of opinion...the other guy in my thread couldn't just get that ....
ryzengames
