Google Pay Issue
is the p5 locked or unlocked? If unlocked did you unlock it? will the card setup and verify on samsung pay? It is just to troubleshoot. You can delete it once you know...
I don't think you can put Samsung Pay on a Pixel. It's not available to install on my Pixel 4 XL
Ok, so I figured out the issue or at least something that worked. I had to remove any subscriptions I had on those two cards, YTP for Amex and Google 1 on USAA debit. I added them to my Discover card (temporarily) and was able to remove them from GP on my P4 and successfully add them back to my GP account on my P5 and then change it all back from my Discover card back to original cards.
Definitely should not have to have done all that but it worked and I used GP at the grocery store today w/o issue. Hopefully this helps someone else in need that hasn't figured out a fix
wrathcode
