Google Play Error Solution [RPC:S-5:AEC-0]
Re: Google Play Error [RPC:S-5:AEC-0]
Was having the same exact problem. I was forced to use the "Create New Account" fix. Signed up for a new Google account. Updated one app using that account. Signed out of that account and into my main account and everything is working now. My suggestion would be to keep the temp account you've just created in case this happens again. Just a suggestion.
I also had issues with Google+ connecting after clearing GSF to get the 4.2.1 update. Deleting my Google account and re-adding it worked. Thanks for the help everyone.
I have a tablet pc vero and i have the up write problem.thanks!..play store this problem.
Remove my google account from the phone or just from the play store? If I only have one account on the play store I can't figure out how to remove it from the play store unless I create a new account. That didn't work anyway. I am on 4.2.1 on a Gnex.
- - - Updated - - -
Did you delete your google account on the phone and then add it back? Or just in the Play Store App?
This worked for me. It took a bit of time to sync everything, but it's all there.
Just go to settings and remove Ur Google account, make sure u know Ur username and password. Then open play store, it might force close a few times then should ask u to select account or something. Obviously select existing and than login no problems at all
Was getting the server error message since yesterday after updating to 4.2.1 and could not download or update any apps. Just signed out of my Google account, and cleared out the data on Google services framework. Also turned off the device, waited 10 seconds and restarted it for good measure..
Signed back in and no issues.
- - - Updated - - -
Delete your system Google account, not the one from the Play Store.
The problem at some devices is from google. Don't restore your phone or reinstall the rom because is not the first time Google have this problem. Normally is up to tow weeks the problem. Especially from friday
I had this problem [RPC:S-5:AEC-O] & I solved it this is how, I did this 3 times before it worked on the third time when signing in to google I joined google + I think that was what it's called after that no problem
Sorry I forgot to say that I reset the tablet three times
i can't install any applications at all in jb 4.2. What are some possible solutions? I'd attach a screen shot, but i'm guessing i've reached my daily limit. The solution to this problem:
Sent from my nexus 7 using android central forums
ghaa this dosent work! Im try to add a reffilable credit card on there but its telling me about this [rpc:s-5:aec-0] and inside mycards 60.00 bucks! Dont tell me i wasted my money for the dang card >:(
Thank you all for posting here. I got my Nexus 7 to work. You guys ROCK!! The Nexus is new so I just did the global reset. It has downloaded everything now! Thank you!:D
Just trying to set up a cheap android tablet with apps for my kid but keep receiving this error message, what can i do? pls someone help.
(mystery solved)After like hours of tryin to fix this it?s fkn simply as i expected. JUST CLEAR data/cache for Google apps most importantly FRAMEWORK,than restart your device and your good to go.Cheers
I was having same prob and fixed it within 5 mins ....ITS THE ONLY SOLUTION I HAVE FOUND THAT WORKS.....
Go to SETTINGS > APPS > ALL > GOOGLE FRAMEWORK + CLICK FORCE STOP.. THEN CLICK..CLEAR DATA..... TURN TABLET OFF FOR 5 MINUTES... RESTART AND IS NOW WORKING FINE.
Thanks guys, the clear down of framework did the trick for me. Had spent a couple of hours trying prior to this.
Cheers
Rob
This works for 1 app download then on next app download its back to same error.
Is there a permenate fix?
Ashok Dharshan
