Google Play Store Not Working
Status
Not open for further replies.
I have a galaxy s2 my play store app keeps saying invaled password but ive changed it like 10 times trying to make it work but it still says ur passwrord or username is wrong or ur Aaccount has changed how has it changed if I didn't change it.... also its saying I have to update my facebook and instagram apps or ill no longer be able to use them but I cant update them if I cant get on my playstore app in the first place!!....
Sincerely, very confused and angry please help!!!
Greetings~
I just bought my Samsung Galaxy Tab 3 8, but as it turns out, it does not have Google Play installed. I tried to install the 4.3.11 version, but it fails to run on my tablet~ it just flashes, then turns off and that's it... Anyone know what the problem is?
Thanks~
my cell is samsung galaxy grand quattro play store is not opening. it shows sometimes connection timed out or not retry connection failed but my whatsapp work veey well plzz help
Re: Google Play Store Not Working [THANKS FiendishMcButton!]
I have the same problem with my note 2 .did you find out how to fix it I get a google.somthing is shutting down and it wont open.thanks.
my tab 2 samsung cant open play store
I try all toturial in youtube but not working, ples hlps
YESSS!!!!!!!! this worked!!!!!!! thank you for the help. i have been trying to get this to work for the past 2 months.
Pls help ihave same issue. .how to fix my play store doesn't work.huhuhu
Status
xinyingt2
