Google Play Store Not Working
Status
Not open for further replies.
HOLY CROW! That's it! On the Samsung Player there is no enable/disable option. That's VERY FRUSTRATING! However, I just reset the date and time and now it's working! Thank you Mrsmumbles!
I'm glad it worked! :thumbup::)
Sent from my LG870 via Tapatalk 2
Set your correct date and time for the current location. Try this it will work out, and also try to inactivate your play store account and reactivate.
i have tried this & its working for me Thanksssssss a lot ............ :D
Settings > Application Manager > All > Locate Download Manager (will be at the the bottom of the list when it's disabled) and enable it
Hope that helps
Hi i have a galaxy tab 10.1 every time i open play store it says no connection retry. But it is connected to the net. Please help i have tried few things and now i am so stuck on what to do.
Try resetting app preferences. Settings, Apps, tap the 3 dots, Reset preferences.
If that doesn't work, try resetting the date and time. :-)
Sent from my Nexus 5 using Tapatalk 2
Is the time set up correctly?
sent from my N4 with half of the screen working
Hi, the play store is not working for me, I have tried all of the solutions that have been posted on this site. I have the. Moto g can someone please help, I need to download apps.
Did you try Settings,Apps,All,Reset Preferences ?
If that doesn't work, try resetting date and time.
Hi All, haven't been able to update or download anything for last few days it just sits on downloading and doesn't do anything and I have to cancel the download. It's the same on my tablet and Sgs3 I can download from Samsung application store perfectly. I Have tried clearing cache and data for download manager and Play Store application so all in all it points to a problem with the Play Store itself. I know they had a major update last week to change the way it updates apps maybe this has caused and error?
Anyone any ideas or having same problem?
Thanks
Why is my Google play store is not responding?
Hi,
I am using s-7562(duos) model from samsung but i am unable to use play store everytime it ask for registration
after filling all the details in last page it shows cannot sign in ....try later of else contact customer care.
Please suggest customer care for Samsung or else for vodafone.
Re: Play Store Not Working
Had the same issue as most on here and found that my date and time were not correct at all, which is odd because I just set my Tab 3 up yesterday and it worked until mid-day today. Corrected the date and time and my Tab 3returned to working order immediately after.
Hai Guys, can you help me? My play store in samsung galaxy s duos 2 does not work. I mean you cannot install any app...
Please help me please please
Status
vdacau
