Google Play Store Not Working
Status
Not open for further replies.
my google play store is not working every time i open it it just always says : no internet connection but im connected to our wifi
PLS ANSWER ASAP:'(
well hell after hours of searching and doing all the possible solutions I had read, I FINALLY FOUND THE RIGHT ONE! Resetting my apps that's all. By far, after resetting it~ no problems yet encountered. And i really hope I will not encounter another TRICKY shiz again soon
Am really dissapointed with my samsung grand cant do anything coz it keeps tellin me my google play store not working wat should i do???ill appreciate any help..
I tried to open playstore then it just chrases down its on my tab 3 and i had just goten it yeasterday what should I do ?
I have problem with my play store!!!
I can't download anything from that
There is an error that fu..ed me (403)
Help me plzzz
Try what the person a little above did.
Phone Settings - Apps -
Tap the menu button, Reset Apps
Sent from my LG870 via Tapatalk 2
I have been researching the Play Store- no connection; retry issue and it sounds like FiendishMcButton's trick is just the answer except I do not have an enable/disable option. It is for a Samsung Galaxy Player YP-GS1. I am having a devil of a time weeding out any information on any site so if you are able to help me, i would appreciate it! Thanks!
Thank you for this the excellent direction to solve the Google Play Store dilemma. It was a simple, quick fix.
Nothing comes up under Apps when I press the menu button. I tried under Samsung Apps and "Reset Local" came up but when I reset that it did not correct the problem. Any other ideas?
This advice is from Anne:
"I searched ALL over to figure this out....and here it is...so simple!!
If the link doesn't work, the directions are:
1. Go to settings
2. Open Application Manager
3. Scroll to "All"
4. At the VERY bottom you see Downloads. (Betcha it says "Disabled"
5. Enable!
That's it! "
Sent from my Nexus 5 using Tapatalk 2
Another recently posted solution was check the date and time. If they aren't accurate they could be messing stuff up.
well it even happened for me.
Try to check whether Download Manager is enabled or not. To find this Go to settings<application manager<all <select download manager.
If it is disabled?Just Enable it!
Hope it helped you!
Status
dumpsterrentals101
