Google Play Store Not Working
Status
Not open for further replies.
Greetings~
I just bought my Samsung Galaxy Tab 3 8, but as it turns out, it does not have Google Play installed. I tried to install the 4.3.11 version, but it fails to run on my tablet~ it just flashes, then turns off and that's it... Anyone know what the problem is?
Thanks~
Mate, it's simple. Go to settings and then application manager. Then go to Disabled apps which is right to"all" then click the app that is disabled(most probably downloads or download manager) and then enable the app/s . This should work
Re: Play Store Not Working
My Play store doesnt Work! What should i do to make it work again? I need to fix this cause i need to upgrade my apps! My Phone mode is Xperia LT15i sony ericson... pllss help me..
I have a Samsung centura and I'm having the same problem. I have tried all the fixes and nothing has helped I even cleared the partition cache and re booted nothing has helped
Hai good noon frnds.
im using samsung galaxy y duos,
for past 10 days i cant use my play store. it simply saying no connection
but my wifi strength is very good, plz help me to resolve my problem.
Google Play Store Not Working on my s5
Everytime I try to download something on my Google play store...it says error retrieving information from server..please help me this is annoying I can't download anything on my phone anynore.
just popped on here as my play store was not loading, followed FiendishMcButton's suggestion and its working a treat, many thanks as I was close to throwing my S4 at the wall.
my play stor Does not work >.<
And since this program has Taysyr activity can reduce the mobile phones and other problems have been
I've updated the program but became worse
My cell phone is a model galaxy grand
Please help me: (
Re: Google Play Store Not Working [THANKS FiendishMcButton!]
I seem to have the same problem. When i try to download an app keeps saying 'downloading' but nothing happens. With 1 or 2 worked, but now it doesnt work at all.... And it happens when i'm on my wifi. Cause with the mobile data is perfect. But it can't be the wifi because all my other devices work perfectly. I've tried to clear data and cache and force stop the play store but still nothing...what can i do?
Hello out there! My Samsung Galaxy 10.1 has not been able to connect to the 'net for that last month. I searched the Forum's for an answer and was appalled by how many people there are out there with the same problem, good connection but no Internet. I tried a lot of suggestions without any luck until I tried deleting the data and cache in the "All" area of Application Manager. I worked first time.
I joined your Forum so I could pass-on my thanks for a job well done.
To solve ur problem i may suggest you few steps may be it will be helpful to you
Before doing this process backup your data
Firstly shut down ur phone
Then,
Hold Volume down button + Home button + Power Buttton
Afterwards, It will reboot the phone and some options will appear i.e. Wipe out debug,Format factory reset,reboot
Then Select Clear Cache Partition
That's all
I think you should try using the simple way :
Got to < setting< Application Manager<Select All<Google Play Store< Clear Cache<Uninstall Updates
Reboot
That's all
HI,i have a Intex Aqua Y2 smartphone my phone is automatically updated to Google Play Store V5.0.38 and when i'm trying to open it is displaying white screen.I have already tried to clear cache and uninstall updates and even disabled auto update of Google Play Store and Download manager is already enabled it is not showing enabling option ...............
I'm temporarily using my phone by uninstalling updates everyday
Plz help me
Hi All, haven't been able to update or download anything for last few days it just sits on downloading and doesn't do anything and I have to cancel the download. It's the same on my tablet and Sgs3 I can download from Samsung application store perfectly. I Have tried clearing cache and data for download manager and Play Store application so all in all it points to a problem with the Play Store itself. I know they had a major update last week to change the way it updates apps maybe this has caused and error?
Anyone any ideas or having same problem?
Thanks
I am facing difficulties in Google play store as " Unfortunately, Google play store has stopped"
Anybody help me.. Plxzzx
Try clearing data AND cache for Google Play, reboot, and then try again. Settings>Applications>All>Google Play>Clear Data and clear cache.
EDIT: posting in the right section is always helpful :)
Sent from my phablet.
I tried deleting the cache n data from google play store. Tried rebooting n it doesn't work. Even took out the sim card sd card n battery n rebooted. That didn't even work.
Status
pmm09
