Got 10 on Wednesday battery drains faster than my m8.
Very good results indeed.
Would you say the signal quality is quite good at your location?
Thanks
http://i.imgur.com/KBCje8c.png
http://i.imgur.com/6NXrONJ.png
These are after the first week with the phone
These are after longer amounts of idle times
http://i.imgur.com/CJYViYw.png
and this one is after 2 and a half days of light use
http://i.imgur.com/L91EgjD.png
I'd say you have to break in the battery first and have Doze do its learning. Took me a week before I was getting results like these, which are pretty good imo.
I have had the phone for about a month and I get nowhere near the better life you have done. What is doze and how do you activate it. Or is it something part of Android. And how does the GSM battery app help with battery more than the stock battery monitor.
Greenfid28
