Grade papers on Galaxy Note 10.1?
Ok. When you select import inside of snote, don't click on the file itself. Select the button on the right. It took me a minute to figure that out as well.
Ya oook that's a really annoying process . I get it now, but that's why I way prefer Repligo
ahhhh the old radio button selection!
Thanks for educating me :-D
NOW I SEE the standard s note tools
Duhhh senior brain, needs more wine today
Still prefer Repligo for pdf edits
Doing this with Lecture Notes by adding an additional layer to preserve the original document is so easy. Give Lecture Notes a try first. Easy to import/export pdf files. Far exceeds the other applications.
Via my Note 3
Others have also said they like Lecture Notes, I may have to give that a look too
I decided to give the 10.1 a whirl for grading. So far, I think I really will be able to grade papers using Kingsoft Office. The version that came installed on the tablet didn't allow annotation, but if you go to the Kingsoft website, you can download a version that is made specifically for Note devices. It doesn't allow for annotation on PDFs, but it allows you to write comments on Word documents. Initially, I had trouble getting my handwriting to work properly in it, but I think it just gets confused when I lift my hand while writing. It needs you to leave the stylus on the screen until you've finished a word. I've also downloaded Repligo for PDFs.
