[GUIDE][8/1] Jelly Bean Now! Resources & Discussion
Re: [GUIDE][7/1] Jelly Bean Now! Resources & Discussion
Jake said he will post the change log when he gets home from work... Should be up in an hour or so.
meh, not like i'll wait anyway :)
just waiting for someone to put up the md5
i think beats was added in, based on one of the comments
edit: flashed 1.9 no issues... same great work, same sh...oddy GPS. gonna try to do a clean install first, followed by an AOKP reversion, and if needed, going back to bone stock to see if my aGPS is actually working or fried
Now running JB14 1344 kernel. Seems to be running fine. However, I am not seeing any Deep Sleep now. I have been since running Vicious v2 from day 1 with 3 different kernel's with no issue, but now... nothing. I don't have the Trinity tool kit. I am currently using Franco app or SetCPU. Is there some setting that I'm missing?
*Update: apparently, my phone hasn't had a reason to go into deep sleep yet.
I realize that Google now needs to have Google location services turned on to operate correctly. Is this just something we will have to deal with from now on?
There is a lot more awake time with all of the location services turned on. Let me know that I am not alone so I don't go nuts again trying to figure out what's keeping my phone awake.
Alright I messed up my phone, that's what I get for messing with it when I don't know what I'm doing. I cleared everything then flashed Vicious V3 then I flashed the trinity TNP1344-384-ALPHA95 Kernal and now I am Stuck in a bootloop, it just says Google. Any ideas on how to fix this?
No problem, that's why we're here.
You want to download (1) the 1.8 file, and (2) the GAPPS from 7/1.
Reboot into CWM, do a wipe of EVERYTHING--data, cache, dalvik, and go to mounts/storage and format /system. Hell, do it twice!
Then, flash the 1.8 rom zip FIRST and the GAPPS second. If you forget about the GAPPs, then power down your phone (immediately lol) and flash them.
I recommend trinity, so far it's been the best kernel for my device. However each device responds differently, so if you find a kernel, try it for a day before giving up!
If you want to use trinity, download it, place it on your SDcard (like you would a rom), and reboot into CWM and flash it. I recommend a cache/dalvik wipe b/c that's always safe.
Thanks alot for the help. Much appreciated! I'll take the plunge when I get home.
I had this problem after flashing Vicious V3 and rebooting without any other mods or kernels. I wasn't able to restore a CWM backup or flash any roms with a data wipe. Only way to fix it was to restore to stock. Just search how to restore Galaxy Nexus back to 100% stock. You will lose all your data, but you might be able to do a data wipe in CWM then do the fastboot update without the -w modifier.
You might try flashing the stock bootloader and radios, then a 4.0.4 or older rom with a factory reset. No guarantees on that but worth a try I guess. If not then follow the full restore, but don't put the -w in the "fastboot update" command. If it still doesn't work you're gonna need to do a full wipe.
Probably should try what dmmarck said first, but I had no luck with that.
1.9 flashed and so far running smooth and fast
It might take five to ten to load up the first time. You sure its not just taking a while?
This. Wait a bit!
Thanks for the other roms; were you watching the Razor drama at DW? Kinda nutty.
thanks to dmmarck and others, i'm rockin' jellybean! much thanks to all.
Deep sleep in that regard is not really the kernel, but the constant location services/search services. It is something we're going to have to deal with, I reckon.
In order to get deep sleep, some have turned on maps, let it find them, then closed it. Some say it works, some say it doesn't--worth a shot?
GPS is way, way, WAY off for me on Jelly Belly 1.9.
so my gps file is -r- only. any way to set it to rw without purchasing root explorer? is there an adb command
edit: can i use "chmod 777 <filename>?
What file explorer are you using? There should be an option to do it somewhere...at least with ES Explorer, IIRC.
Then perhaps GPS is all awry.
FWIW, mine's working brilliantly.
i think im gonna try the scorched earth policy with my phone, and wipe it all, and try 1.9 as a clean flash
santhoshxx
