[GUIDE][8/1] Jelly Bean Now! Resources & Discussion
So is it really worth flashing the JB bootloader or just stay on ICS. I have the 4.04 if for some reason it makes my phone act wonky, ideas?
Now that its aosp and not a port, isn't job boot loader required?
I have seen different post saying yes and others saying no, so I wanted to ask the guru's here on AC
Re: [GUIDE][7/6] Jelly Bean Now! Resources & Discussion
friggen PERFECT timing. Was just getting ready to throw in the towel and DL jellybelly 2.6 hybrid, and I look over there and see 3.0 is out!
I will also be waiting for 3.1 though, I must have my google now fix. Shouldnt be too long...
I caved and flashed the JB bootloader earlier today, and I was a stubborn holdout. So I say just go for it :)
Reactions: DB12088
rumor has it that D was going to post his Jb master piece. i probably can help with your fc issue
Thanks 2def, here goes nothing
Edit: just to make sure I factory wipe, wipe cache, wipe davlick, format and flash bootloader , rom and gapps?
Did I miss the 2nd Cominng of Jelly Belly??/ Fk I pounded a few bruskis and ...fk it I;ll ewait tikll tomorrow.
I'm going to post up a version of Prometheus a bit later...the updater script is a bit long but entertaining. Still figuring that out.
It's rooted, CWM sticks, and you don't need to flash anything else.
will jelly belly 3.1 have an swagg built in? when will the swag come?
Can someone please explain where to find the JB bootloader to download so we all can flash it? I don't know if this is just an oversight or a well kept secret. :p
It is on the jelly belly 3.0 thread on RootzWiki
Reactions: Nakrohtap
Jelly Belly 3.1 is due out in about an hour... According to Jake on IRC
no but i can add it if you want. when you post your rom latter and then re upload it
Sent From my JellyBean Powered Galaxy Nexus
I'm 90% sure I just added it, I'll let you know once I'm in.
ok. there is also a busybox installer app in the play store that should also do the job. are you still FC?
Just Talk and Gallery. I have no idea what's going on with it. I'm going to give it a break tonight then hopefully the real devs will have figured it out.
Doesn't seem to matter which GAPPs package I flash, either.
spade20
