[Guide] How To Root Samsung Transform Ultra
I have done this flash nearly 10 times and it wont flash to the 'T'.. I have even loaded the super user to the phone and still nothing.... I cant get Jellybean to flash to the phone. I don't know what more to do as I have followed each direction as it states.
This is the only way to root the Samsung Transform Ultra.
Jellybean is not available for this device. This device is unable to handle Jellybean.
So your saying that this process was not to have the ability to install Jellybean? I guess I misunderstood.
Jellybean was never part of the process. You may have misunderstood that this is for the Transform Ultra and not the Transform. Two different devices.
How do I reboot after you install the tu_root.zip file in recovery mode? Do remove the battery, put it back then power up or do I hold down the power button. I tried the first option I mentioned but when the phone powers up, I can't find the superuser application you mentioned listed in my apps. What did I do wrong? Thanks for your help.
You did everything right! If you look through the posts you will see where I mentioned some users missing the superuser app. There is a flashable file in that post which needs to be downloaded and flashed in cwm.
Here is the post --->http://forums.androidcentral.com/showthread.php?p=2658370
i tried and it didnt work!
Put the file on the root of your sdcard. Then powerdown device. Get into recovery. Choose install zip from sdcard. Find the Superuser.apk. Press power button to select. Scroll down to yes and select. Let it finish. Reboot.
at the end of the odin when I pressed start it said please connect pones and my phone was connected and I completed all the steps correctly please help
Sorry my device has been down for a couple of days.
You need the latest Samsung drivers. Goto the Samsung website and receive the download from there.
Sent from my EVO using Tapatalk 2
I Cant seem to get pass "Pop up on computer" i have windows 8 on my laptop if that means anything ... & i don't get the pop up only thing that pops up is if it wants me to import all my pictures to my laptop.
Windows 8 works just fine. I used win8 as well.
Did you run the Odin.exe?
Also is your device in download mode? It looks as if, your device is connected as normal. It must be in download mode.
I have my phone rooted alright but my mms will not work. I can send texts but not photos? Running MegaTron 6.1.1. Android version 2.3.6 I have tried:
I haven't been able to send sms since I got my phone. I have tried this:1. From the phone dialer, dial ##3282#.
2. Tap ?Edit.?
3. Tap the text field to bring up the keyboard, then enter your MSL (******) from above and tap ?OK.?
4. Tap ?Others.?
5. Tap ?MMSC URL.?
6. Tap ?mmsc.? If the URL doesn?t say , change it to this.
7. Tap ?OK? even if you didn?t need to change the URL.
8. Turn your phone off and back on.
to no avail and I have also tried this:
Install APN Backup & Restore from the Google Play Market
2) Download and unzip the Credo-apn.xml from the download link below from this post.
3) Mount your Android mobile device to your computer; at the root of the sdcard, create a folder called "ApnBackupRestore".
4) put the Credo-APN.xml file in the newly created folder and unmount the device.
5) Run APN Backup & Restore,
6) Backup your current APN settings
7) Delete APNs
8) Restore APN and select "Credo-apn.xml"
Neither one of these approaches have worked. I have tried sending sms through the stock messenger and also through go pro and handcent... Please help! Thanks for your time =)
You need voice dialer apk for this to work and speech recognition.
Open voice dialer and say "open APN".
It will then open up the APN menu.
From there you should be able to change the mmsc to the appropriate carrier and "make it stick".
opegamani
