[GUIDE] How To Root/Unroot The Thunderbolt with Revolutionary
I followed the directions to a T - both on this thread and the XDA-Developer's .9 to 2.11.605.5 reversion...
it still works!
Now if that unrooted and debloated 2.11.605.9 OTA update from JCase can be re-hosted somewhere... I'll be happy.
ONE QUESTION: How can I be sure to no longer receive automatic OTA updates? Does the rooting process itself block further pushes, or is that something I need to manually do? I ask, because I have no plans for custom ROMs at this time....
Thank you all for your efforts!
no, unless it was removed from the ROM...I dont know personally if it was..best case is reread the thread(from the ROM) to see, or ask in that in that thread...if it is debloated I would assume it is set to NOT receive OTAs...
Downgrade procedure did nothing!
what do you mean? When you check your software version you're still on .09? If so then you missed a step or did something wrong. It has worked for many people on here.
If I use this and then apply the locked bootloader (Thunderbolt_Patched_hboot), would that still work?
Thanks so much for this. I've been debating rooting for awhile, and I have to say, if I knew it was this easy I wouldn't have waited. It worked flawlessly.
I just got a referb and it has GB 2.3.4 ROM 2.11.605.9 I have everything set up correctly and for some reason I keep getting "Failed to get Root! :<". I've rooted the adb way and I am just to lazy to go through the process again. Anyone else go through this. Not sure if it is GB Radio (although everyone says there is no problem).
Any help or insight would be appreciated. I have reset my phone numerous times, bugging on, charge only, no HTC Sync, re-downloaded HTC Driver's and re-installed. So Not sure what is going on.
***edit*** Need to downgrade baseband
After rooting my phone, flashing a ROM(BAMF Forever 1.0.5) and the MR4 radio I no longer get a 4G signal.
Has anyone else had or seen this issue?
Order of steps I followed:
1. I used XDA-Developer's instructions on downgrading from .9 to 2.11.605.5
2. I followed the directions on this thread to root my phone
3. I flashed a ROM using ROM manager
4. Had issues with the automatic update of .9 constantly trying to be pushed to my phone (very annoying)
5. Reflashed the ROM manually which resolved above issue
6. Flashed MR4 radio
Phone functions fine(much better than before (wish i would have not waited to root) and I have a strong signal strength but it never goes to 4G it is constantly on 3G. There are no known issues in my area with Verizons 4G network.
Any help with this would be greatly appreciated.
Hey guys,
I need to send my phone back to Verizon for a warranty replacement and one of the files I need to unroot revolutionary is unavailable now that megaupload is shut down. Does anyone have another link to the file or can someone email it to me? I am in a bit of a bind because this thing needs to be back to verizon in about 4 days. The file I need is tbolt.zip from the revolutionary unroot instructions. The post says the file contains the old eng 1.40.2000 s-off hboot,and the bare minumum tools to install it. Any Help?
Hey guys,
I need the same thing. If anyone could help, I would greatly appreciate it.
Hey guys,
Here guys: File contains the old eng 1.40.2000 s-off hboot: TBolt.zip
Let me know if that works... it should.
Reactions: smarblewnec
Thanks very much for the help. I would have used your file but before you posted it I found the below link instead which worked very well.
Thunderbolt Auto-Unrooter!
Since I didn't use your file I can't verify it, but I downloaded it anyway for future use if required. Thanks for the fast response.
This method worked great, once I figured out that you have to remove the PG05IMG file from the SD card, then load the SU zip file. Was a little frustrating at first, but I did it and that is all that matters. Watch the video! It really helped.
Thanks for putting this guide together.
Sorry if this has been discussed within the 54 pages of this thread, but is it still not possible to root with the .9 instead of .5? I've tried downloading the downgrade patch but it's going to take roughly 5 hours (when it doesn't just stop downloading) Thanks!
I am unable to see the .zip files in recovery window to install. I can see it when its mounted as a USB drive though. any ideas? Thank you. (I am still browsing but 54 pages is a bit of reading=)
Nevermind, I created a directory with my name, placed zip file there and was able to install it=)
i downloaded everything needed but when i try to open the adb application it opens then shows a bunch of comands but instantly closes afterwards and i couldnt read anything that it said...any suggestions? if u dont mind could u email me stephonchavez@yahoo.com. i dont get on here that much
OK, for the other person that didn't have internet on his PC, I've searched other forums and found a way to do the install without an internet connection to install Clockworkmod manually.
xda-developers - View Single Post - [Info] After Revolutionary: install Clockworkmod, root & more
When done, continue with the first page instructions to complete the root.
OCMDDan
