[GUIDE] Optimus V ZVJ
Re: [GUIDE][WIP] Optimus V ZVJ
they were registered, i dont have data since i did a restore 2 weeks ago, and didnt backup nvs files, lgnpst doesn't show any aaa/ha keys when i press read now :(
What happens when you run lgnpst and then try dfs remember that it might not be profile 0 it might be one two or three? If you have confusion about that then watch this here video.
So question. The fix that zakman posted so that the jb cm10 rom would boot, would that work on any zvj roms? Cuz then there's not really any point in getting the zvj radio on our phones. Or is there another reason we should want this radio?
Where is this at? It might be helpful in other areas as well as letting someone flash the stock gingerbread rom without having to flash the sprint radio.
True! Maybe I should try it. Ahhh man that was awesome. fully functional zvj rom on the optimus v. oh for mms, I think it can be fixed pretty easy. Not sure though. Could you try Wraith? in your stock rom, go to phone and dial the ##data# and then there should be one like mmsc or something like that...? it gives you an option to change them. I think that could get mms working if you set it up to be vm.
That may work to get outgoing mms to work but it won't help at all to get mms receive
Reactions: andrewnelson23
LGNPST wont show it even if it is there, what you MUST do is read with LGNPST and then read with DFS from the unbrick optimus v with optimus s firmware guide.
Read what asadullah said before me^^^
Sent from my Optimus M
I packaged a flashable zip with it in there...
I made it for use with jellybean, but it can be used with any Optimus S Rom (ZVD, ZVH, AND ZVJ!) On the Optimus V. It doesn't fix MMS, just everything else, including the button swap.
Now if only I can figure out how to make a flashable MMS fix.. then we'd have a 1 step flashable porting patch for ALL Optimus S roms to work on the Optimus V.
JellyBean Super Fix for the LG Optimus V!
------Installation---(Must have ROM ZVJ WIP CyanogenMod 10 installed FIRST!)---
-wipe cache
-wipe dalvik-cache
-disable signature verification
-flash as you would with everything else
Included is the ZVD radio fix. (Thanks Zakman for providing what needed to be implemented!)
The official CM10 Boot animation (Thanks Nate456 for providing the link!)
LG Optimus V key layout fix (Thank you YoshinJaa for clarifying what needed to be changed!)
Enjoy!!
JellyBean Super fix.zip (1.51 MB) Flashable zip!
sent from my un-dead sammich.
The sprint radio is not what's causing us to lose data.....I think it's letting that sprint program run on the boot after flashing the PRL. I pressed menu key (the key that looks like the home key) and press skip...
This^^^^^ if this was made a day before this guide..............this would not exist.
Reactions: thewraith420
Lol, I'm sorry for making this a little too late :p
If it wasnt for your guide, I wouldn't have tried to find a shortcut.
So if your guide never existed, neither would my flashable zip. PARADOX!
All we need to do, is find a way to make an MMS fix, flashable.
Then I can incorporate it into my zip, and we'd have a 1 step flashing porting zip for all Optimus S roms for the V.
I've been trying to do this since our zv9 update came out lol I'm pretty sure my reception has improved since flashing zvj. So I might be the only one but I'm glad you did this guide.
Tapatalk in it from my VM670 running LS670ZVJ Hydro Rom
Yea but my guide is way too complicated, unless thewraith420 can put in more detail to getting the AAA/HA keys and including a download link to DFS in a single post so I can quote it after saying "To fix data:"
I might be able to do that... Probably not today tho. And I just used the dfs from Phatninja55's unbrick guide
Tapatalk'n it from my VM670 running LS670ZVJ Hydro Rom
I know, but that's like another 100 MBs and some people have DSL....I have cable :D
I love your signature btw :D
How good are you with java and smali?
Updated OP. LGNPST does backup and restore AAA/HA keys :)
I don't know Sammyz....I was pretty sure it was the sprint radio too. but I had skipped that program but I still lost data.
Try flashing the nvs while in regular mode again, then try again from recovery
what do you mean, regular mode? while booted? and then try it from the stock recovery?
If that doesn't work, change it to unknown how asadullah said and then flash nvs.
BrüZZi
