[GUIDE] Preparing your HTC Droid Incredible for the Gingerbread OTA
Re: [GUIDE] Preparing your HTC Droid Incredible for the Gingerbre
Thanks for this information, Stig (and other contributors).
I am running stock froyo (went back to it from CM6). Unrooted, etc.
I have yet to receive the OTA notice, and when I check for updates, my dinc still doesn't get notified. My understanding is the official 2.3 OTA was already out. Am I missing a step?
Thanks
Nope - it's just rolling out slowly. You should get the notification shortly. No one has captured the URL yet.
Thanks Stig. Is there any way to get the OTA sooner (other than flashing the earlier pulled OTA), or do I just wait (im)patiently?
gracias
Stig will be proven wrong! LOL......just playin....
I can't make the nag go away, when i try to rename the file it says that i dont have the right permissions and that it's read only. Any suggestions?
Thanks for the instructions. FYI. AppBrain failed me after doing a factory reset. It did not recognize the phone as the same. It created a new phone in my account, so it didn't provide the easy download/update process it is designed to do. However, I did have the list of apps from the "old" phone there so I just downloaded them the old fashioned way. BTW, it is nice every now and then to be forced purge old apps you don't use, especially as you approach your storage limits like I was with the new OS update.
Thanks again for the detailed instructions.
Sorry for the n00b question, but I am currently rooted and running stock with the latest CWM Recovery. Suppose I install the stock recovery as well, and let the phone update. Suppose I don't care about losing root today.
1- Will anything bad happen to my phone?
2- Even if I lose root, will I lose S-OFF?
Thanks!
Your file manager should have a R/W setting on it that will allow you to modify the file. Different File manager's have it in different places. For example Root Explorer has a Mount R/W button right on the top of the screen.
Thanks!
If you want to unroot and use the Stock OTA you should follow the instructions here:
http://forums.androidcentral.com/in...id-incredible-gingerbread-ota.html#post980676
This will give you the Stock HBOOT and Stock Recovery as well as unrooted Stock Froyo. Then you can go get the GB OTA.
Hope this helps both of you.
Thanks, Stig. Sorry that I didn't phrase my question clearly. Even though it's rooted, my phone is offering me the OTA update. What I'm asking is, what if I simply allow it to update?
If necessary I have the stock recovery... What if I just put that back on there and let it update? Will anything bad happen to my phone?
Thanks again for your help, Stig. I hope you can answer my question above, too... I would strongly prefer not to have to clear my phone's data.
You should be able to flash the rooted update above by just clearing cache and Dalvik Cache (Under Advanced) in Clockwork Recovery - Make a backup first!
You may have to re-install a few apps, but others have had success by just flashing without doing a full reset. If there are problems though then you will either have to do a factory reset or restore your backup, go through the unrooting steps and then apply the OTA.
You will not be able to apply the OTA while you are rooted, the HBOOT and Recovery files on a rooted phone are not compatible with the OTA.
Hope this helps.
Hope this helps.
That worked! Thank you for all your help.
Stig,Adt night was my first night of sleep. 5 football games of editing. Lol.
I thought you said this one is ok to run right over rooted phones. Unless I'm in the wrong thread. Am I even on android central? I thought this was treo central lol.
Tony - use the link in the Sept OTA thread in the ROM's and Hack's forum. That's the latest rooted OTA.
jrkagen - glad it worked for you!
ok thanks.
I wiped my storage by accident and had to restore from a backup.
The Davik cache is in the bootloader screen right?
And for everything else just go into each app and delete the cache?
ok...I just downloaded the one you have on XDA...ugh lol
No need to delete the cache in each app. In Recovery - delete cache is on the main screen, delete Dalvik cache is on the Advanced screen. Then flash in recovery.
The Radio (from the other thread) is loaded in HBOOT.
I feel like I'm chasing... or stalking you in the forums tonight ;) LOL
LOL...wait so I have the right one....
I am not ready to do the radio.
Sorry, I am just not an advanced rooted guy..
Give me software like autocad, etc and I can customize and program the heck out of it with lisp routines etc lol.....
I appreciate it though. I really do.....I am not an XDA member....just too technical for me.
off8485
