pitmasterme
- Jan 17, 2011
- 331
- 30
- 0
You can downgrade your radio version: [ Radios ][ 6-3 ] All EVO Radio, WiMAX, PRI, NV & HBoot versions - xda-developers
Thanks man. All set now. Ready to start learning again!
okay i did this and now my phone will not boot up after several minutes im stuck on the HTC EVO 4G screen..
HELP!
Hey you guys! Im having a little trouble, i followed the instructions and downloaded the S-on tool and PC36IMG.zip. (S-on) is on however the PC36IMG is not loading. it keeps saying no image. I have been doing this for about a day and a half now trying to google the answers but no luck... i hope some one can help me... thank you!
here is what i have on my phone or thats listed
Supersonic EVt2-2 Ship S-on
Hboot-2.10.0001
Microp-041f
Touch Panel-Atmel224_16ab
Radio-2.15.00.11.19
Oct 15 2010, 12:07:00
If you haven't used unrevoked forever in your root process you don't have to use this guide and can use the original how to unroot your phone guide here: http://forum.androidcentral.com/htc-evo-4g-rooting-roms-hacks/19278-how-unroot-return-stock.html
If during your root process you flashed unrevoked-forever.zip or used the Unrevoked program to root your phone then you should follow this guide. In short if you ever had factory software 3.7 or hboot 2.02 on your phone you had to use unrevoked-forever to get a full root.
This guide will return your phone to 3.7 factory software and will restore the HTC security software check.
1. Download some files:
Unrevoked S-ON tool: http://downloads.unrevoked.com/forever/current/unrevoked-forever-son.zip
HTC RUU (rom update utility) for 3.7 software. Get this file: RUU_SuperSonic_S_Sprint_WWE_3.70.651.1_Radio_2.15.00.11.19_NV_1.90_release_161482_signed.exe from here: Goo-Inside.me
The second file is kind of big, so charge your phone in the mean time.
2. Put unrevoked-forever-son.zip on the root of your sdcard.
3. Reboot your phone in to recovery
4. Install ZIP from sdcard, select unrevoked-forever-son.zip (It may need to reboot to complete the process, if so just hit reboot from the main menu and it will take care of it).
5. When the phone boots back up, make sure it's still connected to your computer and run the RUU exe file you downloaded earlier.
Some times it takes more than a few tries at getting the RUU to connect and run, you can try to re-start your computer or put your phone down in to hboot usb.
When it completes you'll be at factory software version 3.7 with S-ON.
Sigh don't you read the warnings?? The splash screen igniciates the boot loader and if it has the wrong binary it will not boot your device you probobly just bricked it see if you can redo it from a back up (if you didn't make a back up your stupid)hi i really need some help with my issue Please somebody. my evo 4g s-off hboot-0.97.0000,radio-2.15.00.09.01, i put the unrevoked forever splash boot animation on and now all my phone does is reboot and stay on the unrevoked forever screen forever until the battery dies and i can not get into recovery and i even downloaded the pc36img from a site and updated it threw holding down volume and power. after that i go to recovery and it reboots the same way everytime...like the recovery is gone or something like the rom idk and i really need my phone. i really need help
