[Guide] Tools and Information for Mac OS X Users - Updated 04/07
so i am trying to get froyo....
So I am following the instructions on this thread and I get up to post #5, step #4.
My screen says:
Andriod system recovery <2e>
Samsung Recovery Utils
-for BML-
reboot system now
apply sdcard:update.zip
wipe data/factory reset
wipe cache partition
I am able to hit apply sdcard:update.zip with my home button, and then I get the following message:
--Install from sdcard...
Finding update package...
Opening update package...
Verifying update package...
E: failed to open /sdcard/update.zip (No such file or directory)
E:signature verification failed
Installation aborted.
Any ideas/help would be greatly appreciated!:'(
Nevermind, It finally worked, I am rooted! Thanks for all your help. Now I just need to figure out what to do with it...
My screen says:
-for BML-
reboot system now
did you do post #4?
this is what i get when i install the kernel:
1-to-2.2/Files/kernel.sh
Starting installation...
failed to copy 'zImage' to '/sdcard/zImage': Permission denied
345 KB/s (313888 bytes in 0.887s)
0 KB/s (24 bytes in 0.066s)
[*] CVE-2010-EASY Android local root exploit (C) 2010 by 743C
[*] checking NPROC limit ...
[+] RLIMIT_NPROC={3712, 3712}
[*] Searching for adb ...
[+] Found adb as PID 2194
[*] Spawning children. Dont type anything and wait for reset!
[*] If you like what we are doing you can send us PayPal money to
[*] 7-4-3-C@web.de so we can compensate time, effort and HW costs.
[*] If you are a company and feel like you profit from our work,
[*] we also accept donations > 1000 USD!
[*] adb connection will be reset. restart adb server on desktop and re-login.
RedBend Update Agent 6,1,14,1
FOTA : Make Block Device Nodes
lcd_init(498): start!
lcd_init(507): fb0 open success
lcd_init(514): width = 480, height = 800
page_msize: 4096, phy_unit_size: 262144
src: /sdcard/zImage
dst: /dev/block/bml7 partition size: 0x780000
part_size: 0x780000
failed to read from /sdcard/zImage (Bad file number)
new-host:Files katesperanca$
phone rebooted as well.
I am in the redclockworkmod recovery.. trying to find which zip to apply, can't seem to locate where the file is
i just realized that I was trying to flash the 2.9.1 patch without having 2.9.
whoops. hopefully this works now.
I disabled lagfix since I was using a nonvoodoo version of super_frackenclean_2_9, still can't find where the ROM is when I "Choose Zip To Apply"
can you boot up your phone and make sure the file you want is on your sdcard and not in any folders
Still struggling. I can't get clockwork to download. "device not found" my process on page 17 is no longer working & I even found some mac drivers to install & that hasn't worked either. Is there a way to down load clockwork directly into the phone & bypass the mac. Mac's just don't work with samsungs
I haven't had any trouble whatsoever with my mac connecting to my phone. What OS version are you running?
Aruz530
