[Guide] Tools and Information for Mac OS X Users - Updated 04/07
Okay, I'm having an issue installing the cw 2.1-2.2 (post #4). I dl to my mac, installed the 1-clish push to sd and that installed fine (post #2). When I click the kernel in cw 2.1-2.2, the terminal has the same message everyone (including me) experienced when running the 1-click root (post #3) and the terminal just sits. I tried waiting longer than I waited for the 1-click to run through (which installed after about 5 minutes), but nothing happens. Any suggestions?
I booted into recovery (blue) and second option is "apply sd card:update.zip" with wipe cache partition being the last option. Do I install the update.zip file? Obviously cw 2.1-2.2 didn't take because recovery isn't red. Is that correct?
this is the message:
:~ owner1$ cd '/Users/owner1/Desktop/1-click-clockworkmod-2.1-to-2.2/Files' ; clear
/Users/owner1/Desktop/1-click-clockworkmod-2.1-to-2.2/Files/kernel.sh
:Files owner1$ /Users/owner1/Desktop/1-click-clockworkmod-2.1-to-2.2/Files/kernel.sh
Starting installation...
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
failed to copy 'zImage' to '/sdcard/zImage': Permission denied
238 KB/s (313888 bytes in 1.284s)
0 KB/s (24 bytes in 0.106s)
[*] CVE-2010-EASY Android local root exploit (C) 2010 by 743C
[*] checking NPROC limit ...
[+] RLIMIT_NPROC={3712, 3712}
[*] Searching for adb ...
[+] Found adb as PID 4385
[*] Spawning children. Dont type anything and wait for reset!
[*] If you like what we are doing you can send us PayPal money to
[*] 7-4-3-C@web.de so we can compensate time, effort and HW costs.
[*] If you are a company and feel like you profit from our work,
[*] we also accept donations > 1000 USD!
[*] adb connection will be reset. restart adb server on desktop and re-login.
looks like red recovery never got installed. you can try it again, and if you get another permission denied try typing
chmod -R 755 /path/to/1-click-folder/
in terminal. then try again.
I remember my first time rooting using the manual method took up to about 5 minutes as well. I didnt remember this until just now, but maybe there is something about the phone that requires more time for the exploit to run when rooting for the first time? Very interesting.
waited 15 minutes and nothing.
typed in the command you suggested and this is the result
235 KB/s (313888 bytes in 1.299s)
0 KB/s (24 bytes in 0.135s)
and my phone froze
rebooted and ran the program again... my Mac kicked my phone out (after 10 minutes) and the phone rebooted...
terminal says: failed to read from /sdcard/zImage (Bad file number)
ran cwm app and get this:
120-MacBook-2:Files owner1$ /Users/owner1/Desktop/1-click-clockworkmod-2.1-to-2.2/Files/cwm.sh
failed to copy 'zImage-recovery' to '/sdcard/zImage-recovery': Permission denied
RedBend Update Agent 6,1,14,1
FOTA : Make Block Device Nodes
lcd_init(498): start!
lcd_init(507): fb0 open success
lcd_init(514): width = 480, height = 800
open device file: Permission denied
bmldevice_get_size: bmldevice_open failed!src: /sdcard/zImage-recovery
dst: /dev/block/bml8 partition size: 0x0
part_size: 0x0
reboot: Operation not permitted
I think the problem is coming from the kernel still working to write to the phone, but the phone gets disconnected from the Mac right before it reboots (casued by the EA28 update). Therefore, the installation cannot be completed. Therefore, I can't run cwm.app to finish the install.
Is there any way to fix this?
Well the zImage never gets copied, and thats the kernel that gets installed. So the phone is just freezing after the root exploit is run...
I'm out of town this weekend, but I will be back on Monday and I can screen share with you to try and get this working. I've also been updating the scripts that check for phone connection before continuing the installation. So I finish, that alone will probably make it work.
Reactions: newBjo3
Not sure if this is the right place to ask, but here goes. I upgraded to SC2.9.1/EC10 using my PC but now need to download my pictures to my Mac. I know we were not able to recognize the sd card as far back as one of the last OTA updates in Eclair (2.1) but I thought that had been fixed with the newer SC Versions.
Right now when I plug into my Mac I get an icon of the sd card but when I see the Fascinate in IPhoto there is nothing there. I've tried to use the sd card with the stand alone card adapter but the side slot on my Macbook Pro seems is to big for this card adapter. Any thoughts would be helpful. Thank you.
Try navigating to the pictures folder through iPhoto and import that way. Rather then trying to add them as if out were a camera.
Sent from my SCH-I500 using Tapatalk
I tried navigating through Iphoto and cannot see any photos at all. Looking at a the Gallery ( 139 photos ) and the SD card, no photos that I can find, it may be that they are stored on the phone memory?. I tried going to app>gallery>move but the move button will not highlight. I don't know what to do at this point.
ok, connect your phone to USB mass storage. open iPhoto, click file > import to library. click on the mounted sdcard in the left under Devices (mine is called "NO NAME"). From there, navigate to DCIM > Camera. And import all those pictures there.
Still need help?
Yup. I totally gave up over the weekend. Even tried it from a PC but the drivers didn't help (downloaded from Samsung). To chap my hide even more, I saw that Samsung released the Froyo update for the Mesmerize for US Cellular. ugh
Do you have google chat set up with iChat?
having a few issues. Did all the oneclicks, however when I try to install SC 2.9.2v it hangs at installing update.
CWM is working fine (2.5.1.x)
Root is working fine....
Just cant figure out whats wrong past that...
How far do you get through the install?
Trying to root using mac!
Using
[Guide] Tools and Information for Mac OS X Users *Updated 3/28*
and I don't have root access, but I DO have the su icon.
This is what I get when I try to plug my Fascinate into my mac and run the root program..
Adell-Coulliette-IIIs-MacBook-Pro:Files AdellCoullietteIII$ /1-click-root/Files/root.sh
Copying files...
error: device not found
So, I re-downloaded set cpu and tried to see if it would work and it said that it can't get root access..
I'm going to try rebooting and see if I get it then.
Samsung...
Galaxy S...
Verizon Wireless...
Lockscreen...
Media Scanner...
Touch Set CPU...
Root Access Not Detected
Set CPU could not obtain root access. Did you allow Set CPU through Superuser Permissions? If you checked Superuser Permissions and SetCPU still cannot get root, there may be an issue with your ROM. Operating in read-only mode.
The main question is.. How do I get my mac to recognize my phone???
I have the stock OTA EA28 update. It keeps saying Error device not found, so I'm guessing it can't see my phone. I know there's a quick fix to this, but what is it? I just can't seem to find this quick fix...
I have issues with some apps now that I'm rooted. Can I use the un-rooted instructions on page 1 without it affecting 2.2?
In other words, I've followed all the instructions on page 1 to get to 2.2 and now wonder if I can simply un-root and everything else will stay the same or do I need a PC and Odin because it's necessary to go back to 2.1 once un-rooted?
Using
Copying files...
Samsung...
Galaxy S...
Verizon Wireless...
Lockscreen...
Media Scanner...
Touch Set CPU...
See post #61 in this thread from poodlecrazy4.
Ok i have tried this but keep getting error: device not found when i try to put in the kernal what do i do now
pratikkumarBB
