[Guide] Tools and Information for Mac OS X Users - Updated 04/07
Voodoo lagfix is actually: diabled
next boot: enabled
/systm lagfix conversion:yes
debug mode: no
Wipe cache partition? don't see dalvik cache
ok, so once I have it downloaded just push it over to the phone? I will need some direction once it's pushed. Also should I push as zip or unzip?
once the kernel is on the sd card, go into clockwork recovery and flash the kernel the way you did the rom
i/o error you can now close terminal. whoops nevermind didn't have card in all the way. Nope still got I/O error. no files found on sd card.
I tried pushto. but even if I put it on the other card and put that card in the phone I get no files found. do I need to put it on the orginal card? I had a spare that I tried with the card reader.
put the file on the orginal card , not in any folders
if I put that card in the card reader the computer doesn't even see it. I would need to reboot phone and hope for coms or put it on other card which oddly computer does recognize. Samsung card actually has one less prong thus that issue. So no card reader for Samsung card.
i think in clockwork there is an option in the advanced section called, restart adb
Reactions: jerseyjim
You are correct. Mac recognizes it now but...
Desktop/Droid/eb16_voodoo_working.zip' to '/sdcard//eb16_voodoo_working.zip': I/O error
You can now close terminal.
I really appreciate you taking all this time to help with this!
i dont know how macs work,,try reboot the mac
I can try it. I think it's on the phone side especially with the phone saying no files found when I try to install zip file from card. It seems to be blank now.
kolorado
