[Guide] Tools and Information for Mac OS X Users - Updated 04/07
ok. Rebooted phone and then my files were back on the card. I installed the kernal and then I thought I was going crazy trying to figure out where this voice was coming from. The phone speaks. I now have:
Firmware version: 2.2.1
Baseband build: S:i500.04V.ea28
Kernal Version: 2.6.32.9
Build number: SCH-I500.EB01
This was the trick, the trouble getting installed just required a reboot
use the voodoo kernel from here
For Real this time: EB16 Kernels
is there anything else I need to do now?
Thank you for all the help!
Hi,
I've tried rooting my phone on my mac multiple times.
I did the command "gpt show /dev/disk2" to get the sd card to mount and then I tried the one-click root.
Every time I do it I get this error message
sh
Starting installation...
Copying files...
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
failed to copy 'su' to '/sdcard/su': Permission denied
failed to copy 'busybox' to '/sdcard/busybox': Permission denied
19 KB/s (5392 bytes in 0.269s)
0 KB/s (24 bytes in 0.082s)
[*] CVE-2010-EASY Android local root exploit (C) 2010 by 743C
[*] checking NPROC limit ...
[+] RLIMIT_NPROC={3712, 3712}
[*] Searching for adb ...
[+] Found adb as PID 2194
[*] Spawning children. Dont type anything and wait for reset!
[*] If you like what we are doing you can send us PayPal money to
[*] 7-4-3-C@web.de so we can compensate time, effort and HW costs.
[*] If you are a company and feel like you profit from our work,
[*] we also accept donations > 1000 USD!
[*] adb connection will be reset. restart adb server on desktop and re-login.
Any help would be great!
Hi,
sh
Copying files...
make sure the phone is unlocked and that the card is NOT mounted
Okay I did exactly that and this is what I got:
Mounting system
error: device not found
Moving su
Moving busybox
Changing permissions on su
Changing permissions on busybox
Installing superuser.apk
Rebooting device...
You can now close terminal.
Mounting system
Moving su
Moving busybox
Rebooting device...
is debugging mode on?
Reactions: andcircuit
Yes, is it not supposed to be?
no its suppose to be, i would try to restart the computer or something,, sorry i dont have a mac so connection problems are beyond me...
try to restart your computer and phone then
as stated in the directions:
Enable USB debugging and Stay awake under Settings > Applications > Development, leave the phone in the Development window
then start the root process over
Worked! Thanks a lot!!! Now to figure out what to do next.
try opening Terminal and type in gpt show /dev/disk1. I also found that rebooting the phone again would sometime regain the connection. I think one key was to be in screen to turn debugging on prior to plugging in usb cable. Make sure mass storage is off. I'm not the best to give advise but I just went through these obstacles and these things worked for using Imac
Trying to root and i open 1 click root, and terminal says "error: device not found". Debugging is checked, stay awake is checked, it is plugged in. I need help
So I'm rooted and i installed 1-click clockwork mod 2.1 to 2.2.
I'm confused as how to get froyo on using my mac, as I haven't seen anything on it.
im confused at your question,,, you said you went from 2.1 to 2.2 but then you ask how to get froyo on. ...........2.2 is froyo
Edit , never mind you just meant you used that package,,,ok so now you need to download the rom you want then push it to your SD card
Try superclean 2.9 http://www.mediafire.com/?ee5l6mkr3bkpdgt
Just by using the one click push to sd? I was figuring that but everywhere I read said I had to use odin and I know its not compatible with Mac. I rather ask before messing it up :)
before you do anything do me a favor
go to settings>about phone>baseband, tell me what it says
araelbenjie
