Gummy 2.0 with IMoseyON 13.6 IS HERE
U need to overclock to 1.4 to get that high. Dowload voltage control from the market.
Does running at 1.4 tear up your battery?
It does but I don't normally run it. Usually im at 1.2 undervolted. I also use the smartass govoner whit limits the cpu when the screen is off. At 12 hours yesterday I had 30% batt left
Has anyone flashed this over EE4 without doing the ODIN of 1.9 then the radio? I am in an area that i never lose 4G and was just going to flash over EE4 via CWR. Any issues doing so? I have 2.0 dl'd and ready to flash. Just wanted another opinion.
I was running on GummyCharged 1.9.1 with the EP1Q radio and I flashed GC 2.0 with CWM without any issues. ( I wiped cache partition and dalvik cache before flashing)
Reactions: bellison41
Ive read several posts about flashing the 1.9 then using CWR to flash 2.0. I was just going to skip the step of flashing 1.9 with ODIN and flash 2.0 over EE4. It doesn't seem that I will have a problem.
I have ODIN v1.3 and it works perfect for me. Like the old saying goes, if it ain't broke, don't fix it. Are you completely stock? If so, flashing the ODIN file is the best way to go.
Its just a recommendation, its not nrcessary. However 1.9 the full odin pachage also has voodoo if u don't already have it.
Rooted stock. Rooted via installing rooted kernel.
Thanks for the info. I installed the voodoo PB&J kernel. I think i will go ahead and flash 2.0 with CWR. Thank you for fast answers. As always AC forums are the best.
I would recommend the 1.9 flash first via odin. There have been some issues wiyh people just junping over. B sure 2 do a factory reset prior. If you have cwm wipe cache and dalvik
Halo
did he release a 13.7 or what were the tweaks. I haven't had any issues.
For some reason he labeled it version 1.1.0 Not sure why? The only issue I had was the HDMI mirroring not functioning. 1.1.0 fixed that.
Ok I'm running 1.8.5 with PBJT and lagfix. So let me understand this I need to flash 1.9 with odin then flash 2.0 with CWM then flash the EQ1P modem with Odin? Do I need to disable lagfix before doing any of this?
No, you upload 2.0 via CWM, it comes with imoseyon 13.6 kernel. Then odin the EP1Q radio. No disable on the lagfix
I was only suggesting Bell.. to flash 1.9.1 first because he wasnt already on gummy. Just make sure you do a data wipe and cache/dalvik
Do I have to extract from the zip file or can I just put it (GC 2.0) on my sd card the way it is? Which order should I do it in? Load the radio first or 2.0?
When I go into titanium backup and I hit the menu button then hit batch whats next? Do I want to backup all user apps, system data or all user apps+ system data?
Reactions: sheldonblack
stoffe949
