GummyJar - ROM
By "stock" I assume you mean un-themed, correct? If so, what will happen if you use this with a theme? Just curious.
Also, anyone got a tip on how to add the blur phone dialer back?
Fixed.
I got this from another forum to share w/ you guys. (I ll just post links from now on I guess ) but it seems that these service.jar are exclusive to what you have on your phone at the time. If you have the watermark theme then you'll need the hacked Watermark service.jar. I think one was just made for the Linear theme as well. If you want the link ill pm it to you or Rion might post it. I see him there from time to time.
Sent from my DROIDX using Tapatalk
Anyone know how to get speed dial? I use it quite often and it's the one thing that's irking me about this rom, otherwise it's fantastic. Gonna go back to the blur camera but I might have to go back to the blur dialer too.
if your refering to the dialer, you'll need to do some research on this to see if possible with this ROM. I've installed the Blur Camera no problem as this was taken from the Fission ROM, but nothing is out yet on how to add back the dialer. try the droid forums as folks are asking about this there, but keep in mind that this ROM is a blureless ROM. if you want some Blur features, you might want to try ApeX.
Another suggestion is to get ADW EX Launcher. You can create a shortcut on your desktop with a "Direct Dial" contact.
yes, widgetlocker works just fine with this rom, just keep in mind that widgetlocker is a bit buggy w/ the 5 second rule, etc.
Thanks I have used it before and like the option to use different wallpaper and clock skin.
Tried it out and loving it. Lighting fast. Only personal complaint is no select all on email and don't like the camera but these are very small complaints
right on! yea, and this rom is great on battery life too. i was on WiFi all day yesterday with 32% Display and I was still at 80% by 8PM. insane!
so, for select all on email....what app are you referring to? this doesnt sound like a ROM feature. if you want the Blur Camera refer to my instruction here:
http://forum.androidcentral.com/motorola-x-roms-hacks/50743-gummyjar-rom-9.html#post501225
Thanks I was just thinking about looking for that. Im using pop email. It had select all on stock gmail never did. And I forgot to mention battery life. Im running dx clocked at preset 1.2 and getting bettter life then stock settings on stock rom
Flashed this rom 3 days ago and I'm absolutely loving it! This ROM is so fast its incredible! I'm also loving the gingerbread feel it has to it.
You serious!?!? Your overclocked at 1.2 and getting better battery life?
Yes not much. About 1 to 2 hours more but still more. Just found one flaw on my phone. Navagation not working but maps do?
Sent from my DROIDX
Is there any themes for gummyjar 2.5?
yes, lots....they can all be found either on xda or droid forums. and they are all very good themes. my favorite right now is MattedBlues:
[Theme]MattedBlues For GummyJar2.5 [Updated 12/30/10] - xda-developers
Sent from my DROIDX
Whats your Quadrant scores compared to stock? I got something intresting going on with mine just wanted to get a census.
Edit: Ok guys next time you overclock your phone....make sure that SetCpu isn't holding you back with that 1ghz preset.....UGHH!!
thelostwanderer
