GummyJar - ROM
ok, just tested....anyone whom wants the Blur Camera can load this file up to replace the AOSP Camera.
Installing Addons
-boot into recovery via clockworks bootstrap
-select "mounts and storage"
-select mount /system
-go back "powerbutton"
-select "install zip from sdcard"
-select "choose zip from sdcard"
-find and select DX_Camera_BlurCameraFromFission_.zip
-reboot
How do I start from scratch? Just so I know in case?
Thanks in advance!
Sent from my DROIDX using Tapatalk
Well if you have a backup of OTA .340 then you would start from there and just flash GummyJar again.
I'm reading on other threads that this Rom doesn't like to be Under or Overclocked, and Themed. So it's a "as is" or nothing for now.
EDIT: Looks like 2.5 is out already...fasten your seat belts guys, here we go again.
I don't have a backup of the OTA .340 or anything. I forgot to make a backup when I was on stock 2.2 and just went straight into flashing roms.
This is true. I have found that GummyJAR, awesome as it is, doesn't like overclocking. Mine gets really sluggish when I mess with overclocking and undervolting settings.
Your pm is full tried sending you one just now
l actually tried the new gummyjar for an hour but back on darkslide again ;)
sent using TaPaTaLk
Installing Addons
-reboot
Thanks for this I like the blur camera way better.
I've been running at ulv underclocked at 300, 600, 800, 1 Ghz since GummyJar 2.1 with no problems. Now on 2.5 and everything is fine as well.
Thanks Rider, I might just give it a shot, after I do a back up that is ;)
Anyone else having problems with custom ringer settings not holding for specified contacts? I've noticed this on many of the AOSP ROMs (Fission, GRummy, etc)...
totally! the AOSP Cam is garbage.
RION J! Thanks for bringing this Rom up again. Its to die for my man. ILove it. Have you tried the service.jar hack yet?
Yea bro I agree, this rom kicks ass! I haven't tried that hack yet. What exactly does it do?
It removes data throttling.
push the services.jar with adb,
adb push services.jar /system/framework/
This ones ONLY for 2.5 unthemed GummyJar
http://dl.dropbox.com/u/11232883/Android Central/services.jar
EDIT: It's possible to push this over any theme.....possible. Plus if you have Root Explorer app. you can do the following....
Find the services.jar file in root explorer, move it. Go into system then paste into
framework. Go into permissions and check the boxes with this pattern:
xx
x
x
Should say "rw-r--r-- if done correctly.
First time i've ever rooted and loaded a custom rom and everything. I went with GummyJar rom cause i really like the Watermark theme. I have a few q'stions. Right now, I have no themes installed I only installed the rom and running it as is.
1) Is there anything specific i have to do to enable gps? I have the gps on, downloaded google maps from the market, but when i open maps, my phone is unable to find my location.
2) I really like the rotary lock, but, when i set up a pattern lock every time I turn on the phone it takes me directly to pattern lock. Is there any way to have the rotary lock come up first and then it ask for pattern lock. Basically how the lock function worked while it was on stock.
3) Would this rom go haywire if I install LauncherPro? (I like the app drawer animation from the Nexus)
4) Is there a way to get rid of one of the Gallery options that is in the app drawer. I like the 3d one better than the 2d.
5) With this rom there's no option to open up .pdf files or word files or any ms office files?
I can answer a few of those, Yes, Launcher Pro should be ok. I got ADW on mine now with no problems. The 2d gallery can be frozen in Titanium and it will disappear from your app drawer. I'm sure there's free apps out there can help you with opening them files. :)
dhickman
