Handcent SMS
Handcent
sometimes i receive double texts. is this a setting? and its not from the person sending the text, and its not always the same person it happens with.
If you get the message twice in your top notification bar you need to open the stock messaging app / menu / settings / notifications should be unchecked
If you mean double sounds (ringtones) Disable the stock app notification... from home screen / menu / settings / sound and display / notification ringtone (notification is the sound it makes when you recieve a text message) / scroll to the top and select "silent"
note: if the selection for "notification ringtone" is greyed out and unavailaible, that means you're currently in vibrate only or silent mode and the option is unavailable - press the volume up button on the volume rocker bar and the option will become available.
sorry, i should have been more clear. i just receieve one notfication, but the message shows up twice when i open handcent. as if the sender sent it twice, but like i said, i will only get 1 notification, and even the handcent widget displays 1, and then i open it, and 2 of the same message are displayed. weird.
Hi,
Using this app for a while and I don't know how to stop it from recording delivery reports. I keep having to go in and clear them, as well as recent recipients. I don't want this information recorded!
Any ideas?
Ta
L
so sad that I only JUST discovered this app. So far it has treated me well with no duplicates.
check out "chompSMS" also -- much like Handcent. I like HC better, but that's why they make chocolate AND vanilla, right? variety is the spice of life.
I'm having a few problems with the settings. I wanted to change the led light color and the track ball flashing. I changed the color setting for the led as well as the track ball flashing. I hit the back button and nothing changed. So I powered off my phone then turned it on. Still no change. What's the problem?
* I'm using the droid eris.
Correct, just making sure it was not conflicting. Go back to the setting, change it again, then go to test notification settings and make sure it works properly there.
Ok try these steps.
Open Application
Press Menu Button
Go To Settings
Scroll to notifications, make sure there is a check mark
Click on notification settings
make sure blink LED is checked, then change color
scroll up and click test notification
I've had notification trouble similar to yours with handcent in the past..the only work around that actually worked was uninstalling, then reinstalling handcent..
arman_kb
