Has the Dec/Jan update made a difference??
Okay, this is the first for me...
Play Store is not responding. Trying to install and update.
I restarted and nothing. Then I remembered to Clear the Data.
Another bug to add on the list?
You force stop it after clearing data?
Well it broke my fingerprint scanner on the AOD. Have to wake the phone to use the scanner from the AOD.
The Pixel 6 Pro since the January release is running fairly smoothly, even more so than prior. However, the unbelievably weak modem is causing very high Mobile Network Standby and Idle battery drains and extremely WEAK CELLULAR RECEPTION. This problem has existed from day one, for myself and many others. For those who run Wifi for the most part and do not have this problem, kudos to you! My Pixel struggles to get five hours SOT via Verizon Business Cellular, strong towers nearby. If I'm in areas where the normal phone gets a decent signal, my phone is fairly handicapped, crippled. For a 5000 capacity battery, this is quite an understatement of 'performance'.
RobKe11y
