Having problems rooting Samsung s4 verizon
Derek11598
14
How to Root Verizon Galaxy S4 SCH-i545! [UPDATED with VIDEO] | GalaxyS4Root.com
Ive been using this tutorial http://galaxys4root.com/galaxy-s4-root/how-to-root-verizon-galaxy-s4-sch-i545/\
and it keeps failing here are the logs<ID:0/004> Added!!
<OSM> Enter CS for MD5..
<OSM> Check MD5.. Do not unplug the cable..
<OSM> Please wait..
<OSM> SCH-I545_MD2_423399_Kernel.tar.md5 is valid.
<OSM> Checking MD5 finished Sucessfully..
<OSM> Leave CS..
<ID:0/004> Odin v.3 engine (ID:4)..
<ID:0/004> File analysis..
<ID:0/004> SetupConnection..
<ID:0/004> Initialzation..
<ID:0/004> Get PIT for mapping..
<ID:0/004> Firmware update start..
<ID:0/004> boot.img
<ID:0/004> NAND Write Start!!
<ID:0/004>
<ID:0/004> Complete(Write) operation failed.
<OSM> All threads completed. (succeed 0 / failed 1)
What Build are you on? It's in the About phone section. If you're not on VRUAMDK, then the root method you're using isn't the proper one for your Build. If your build is VRUAME7, then you need to follow a different method. Here is the complete and essentially fool-proof guide to rooting ONLY VRUAMDK BUILDS. Here is the complete and essentially fool-proof guide to rooting ONLY VRUAME7 BUILDS.
VRUAME7, I believe, is the new update that allows apps to be installed to your SD card. It's more convoluted than if you were just on DK vs E7, but it's completely doable.
athegn
