hdmi mini no audio?
I have an OEM Motorola HDMI cable that worked with the XOOM and it worked with the N10. I've got a weird home set up too; I had to plug the cable into an HDMI switch which feeds into my receiver (which decodes the audio) which then feeds into my TV (all via HDMI). Bottom line: the Motorola OEM cable worked.
Edit: I've got an older rear projection Sony TV and a Sony receiver.
Same deal for me. Works fine with a few year old LG LCD 42LG30. Video but no audio on my 2012 Panasonic 60ST30 60" plasma.
Just hooked up mine today. Works perfectly. Its hooked up to a multi hdmi switch which is then hooked up to my bose system which feeds both sound and vision to my plasma tv. Important I think is to power everything down including the nexus then hook up cables and power up after. Same reverse procedure to be used when you want to take the hdmi cable out of the Nexus as you may damage it. finally I used a Blue rigger 10 ft cable. This is one cool function with streaming from Portal TV and Dice player sweeeeeeeet
I was streaming from YouTube. No audio. So I disconnected cable from N10, played it in N10, then pause it, connect the cable, played.. It works...
Same for full screening.
I've heard that a Samsung cable must be used to hear audio--I tried other brand cables and have the same problem
Are you using a Panasonic TV or another brand? If you have good results with a Samsung cable post your results here.
I am trying to connect nexus 4 to my HP monitor with the slim port adapter for nexus 4 and a HDMI cable (dynex). The video works just fine but the audio is not working. Anyone experienced the same issue?
I had exactly the same problem connecting my Nexus 10 to my Panasonic TV. However, I can now tell you that you will need to connect the audio separately from the HDMI cable. Obviously have your micro HDMI lead connected to HDMI2 socket on the TV. Next, from within the TV menu, locate the HDMI2 channel within the sound menu & change sound from digital to analogue. Use a 3.5mm mini jack to 2xphono lead (choose your length) to connect the Nexus 10 headphone socket to the audio input on your TV. You should now be able to get audio playing with your film on the TV. I have used a good quality QED audio lead. Not cheap but works well ! Something to do with non compatability of the HDMI audio output with that of the Panasonic. Very annoying because like a lot of you, my Nexus 10 audio/visual works perfectly well with just the HDMI cable when plugged in to a much cheaper TV. However, I hope you find the above works well for you.
On a Droid Razr there are settings for HDMI under both 'Display' and 'Sound'.
Sound>Audio Routing> <select one> Phone Speaker / HDMI
This may be helpful for some folks. I never knew there were sound settings (and they can get out of sync) until my headset stopped working - it was set to 'HDMI'.
i have an Asus Transformer tf300t i just got a "rocketfish" micro to hdmi cord i plug in and great video, but no soundi really am not very good with electronics. Help! please
You shouLd ask in the tf300 forum. If it is a Panasonic TV it probably won't work, they seem to have 'issues' and Panasonic isn't interested in helping solve the problem.
Thanks for the suggestion. This worked for me! I had the same problems (Nexus10 & Panasonic)
I'm bringing this thread back, 'cause I've the same problem: Nexus 10 and no sound with micro-HDMI on my 50" Panasonic 3D Plasma.
... so in the mean time, has anyone found a solution to this problem?
Any idea if a fix is underway?
Nope. No fix to the HDMI sound issue on Panasonic TV's. You can do as noted above (connect a separate analog channel) but that is unacceptable to me. I, for one, will never buy another Panny.
I just tried the audio technique for Panisonic tvs and it worked perfect. But I think my cord sucks. Its hard to get the picture to stay on. Have to wiggle the cable a lot.
tinni99
