Help a noob please
Rooted my skyrocket yesterday. No problems. Saw a couple of posts on another site of how to install google now on you ics phone. Made several attempts to install with no luck. All I acomplished was borking google velvet and google voice search to the point where I had to delete them from my phone, so now I have neither. I also did the stupid noob trick and did not do a nandroid backup before I made the problem. Is there any way to reinstall the google velvet and google voice search? I will appreciate any assistance or suggestions you may have.
Mike
Is it just me or did my reply somehow show up as being posted before your original post? Could be the time difference or something lol
Reactions: 26.2man
Put them in the folder you identified and rebooted. Its a no go nothing happened. Any suggestions? Also I noticed your running CM10. How do you like it and what bugs are you experiencing?
Mike
Hmm those should be the files you need, you might have to flash whichever rom you are on again.
CM10 is running pretty good. But there are a few bugs still like random reboots that you might not want to deal with. I'd probably wait a little bit for a more stable build. Make a backup if you decide to flash something just in case :)
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
Reactions: 26.2man
serpdad
