Help! Accidentally wiped my system and data, removing OS.
Jul 24, 2016
20
I was stuck in bootloop but I could access TWRP 3.0.2-0 and I tried normal factory reset but it didn't work so I accidentally wiped my data and system trying to fix. Any way to save my tablet? Samsung Galaxy Tab S 5.0.2
Welcome to the forums. I would see if you can find a stock ROM on XDA and load it to your SD card. From there, you can use TWRP to flash it.
How do I load it onto my SD card and flash it with TWRP? I never done stuff like this I need your help.
Sorry....been away for most of the day. What model is your tablet? As for loading it onto your SD card, you can use a computer to copy the file from downloads onto the card. Don't unzip it; leave it be.
This is where you help me, I dont know anything about roms or flashing roms or nothing please.
The link you posted is confusing. It's in the Tab S section, mentions the S2, but going by the model number it's for the 8.4" variant. I'm going to check something here.
I can only hope that is correct. Without knowing the model number of the device I cannot confirm this will work. As everything stands, this may brick the device. As in, it will become useless.
