Help! Accidentally wiped my system and data, removing OS.
Ok well when I click download it shows these mirrors, the primary shows Canada, I am in the USA should I go for a alt mirror that is closest to me?
Doesn't matter. Sometimes an alternate is faster, but there really shouldn't be a difference.
Downloaded, now do I do exactly please.
On your PC copy the file to the Sd card. Eject, and mount into the device. You will probably have to reboot it back into recovery so that it can scan the card.
Click install. You should be able to navigate to the sd card. Click the file,a nd swipe to confirm the install.
Should take about 5-10 minutes to complete.
So I plug my tablet into my pc and find the sd card first?
Or you can eject the card from the device, plug it into the PC and copy it that way. It's a lot of moving physically, but the write speed is usually faster than through the cable.
That, and I'm not sure you can write to the card when just in recovery.
I am honestly so confused, I don't know nothing about this stuff and how do I eject or mount the file from my pc to the tablet? I don't understand just want my tablet to run again.
Right click on the sd card in the file manager of Windows. Once it's ejected, you can safely remove it and insert into the device. Reboot back into reocvery to force a reread of the card and install the ROM.
Honestly I'm probably gonna break my tablet trying to find out where it is cause I never bought one of those micro SDS you slide in and I can't post pics here
As I recall, I don't think you can push files to the device while in recovery. You should be able to shut it down and resume tomorrow after getting a card.
I vote a round of applause to Golfdriver97 for a magnificent single-handed 17-reply response.☺
koreycabra
