Help !! Galaxy S3 Freezing every few minutes. unresponsive.
The one that you have linked to, I think is the one that messed up my phone in the first place, as it was in January my phone started to play up
Sent from my GT-I9300 using Android Central Forums
That's the one I have right now on my phone and it runs perfectly with it. That's why I'm hesitant about this new one. Scared to go through all the hassle again.
I dont blame you, the grief I have had with my phone the last month or so, Im just so glad its sorted out now
Just a quick FYI....
Woke up this morning to the phone frozen at "Samsung" on the bootup (plays the music, little blue animation, then "Samsung"). I cannot get the phone to boot normally again. Think this thing finally bit the dust.
I never received the update discussed by Tricia.
Trying to determine if there is a way I can save this thing or if I've got Sudden Death or whatever and I have to return it to Samsung.
It's probably worth looking up where your local Samsung service centre is. Call in and get them to flash the firmware, they should do it while you wait. That would eliminate one bunch of possible causes before going though the hassle of returning it to Samsung.
I had the same issue with my S3. Have a solution that worked for me.
Went to shop where I bought it and got replacement one. That did help a lot. No more freezes.
I have the same issue. It started on Tuesday.
It freezes at random moments, and random apps. After a while it unfreezes or reboots.
Has anyone found a solution as to why this is happening? or what I could do?
I am in Costa Rica.
I am running JB 4.1.2 / Baseband: I9300UBELL1 / Build number: JZO54K.I9300UBEMA1
Kernell: 3.0.31-789635
se.infra@SEP-92 #1
SMP PREEMPT Fri Jan 4 19:59:29 KST 2013
Same issue here. Started about 2 weeks ago, randomly. My phone is an aussie Telstra variant, i9300T
Sometimes it will work for a few hours without any issues! Other times it will freeze almost immediately on startup. Once or twice it has frozen on the 'Samsung' boot image, but this is rare.
One thing to note is that I did crack my screen about a month ago and had the screen & digitizer replaced by a mr fixit (so there goes my samsung warranty).
I have tried the following but nothing works:
  • disable wifi
  • remove external sd card
  • installed brand new clean rom (supernexus) - froze even before any apps installed
  • leaving the device for 20-30 mins (sometimes it does come good again but will freeze after)
  • cleaned / checked data, cache, etc
  • fstrim
  • disabled samsung apps
other things i've noted:
  • once, when it froze, i was playing music - it kept playing the current track but didn't continue after that
  • if LEDs are blinking etc, they continue to blink
  • as stated by someone else previously, if i call the phone it rings and rings and eventually goes to voicemail, but there's no notification on the phone that there was a missed call
JB 4.1.2 / Baseband: I9300TDUELL2 / Build number: JZO54K.I9300TDUELL2
Kernel: 3.0.31-750912
dpi@DELL158 #1
SMP PREEMPT Wed Dec 26 20:38:22 KST 2012
It's the SD card!!!! My Samsung S3 has been perfect for 6 months until a few weeks ago when I finally put an SD 8gb card in it.
Firstly it started to turn itself off and on. Then just turned itself off. Each time I couldn't restart it and had to remove the battery. Each time I turned it back on it would freeze within a minute. Couldn't even reboot and had to take the battery out and restart every time.
Finally thought to take the SD card out and it's fine again (so far)!!!!
If you don't need the card, get rid of it. ;)
Hello everyone,
I have got a german S3 unbranded, factory unlocked.
I have the freezing problems similar to everyone.
My firmware is :-
Android 4.1.2
baseband - I9300XXELL4
As suggested by a member here, I uninstalled all updates to the samsung apps application.
For the last 24 hrs no freezing!
If there is anything new..I will keep you guys posted.:eek::confused::D
It has always worked fine, but since about ~ 2 weeks ago (16-3-2013) it freezes or reboots daily from 6 till 20 times a day !!!
This is driving me mad, no one can reach me after crash or while it is in a crash, people at work cannot reach me.
Also i dont have an extra SD card, so SD isnt a problem in my case
WTF went wrong with the 4.1.2 > my phone was always stable until that update.
How could Samsung/Google allow for such bad updates ????
I am sure this is not related to applications as i've had it too with no apps installed.
Also i got slightly less reboots, after i installed a defragment tool (i dont have an extra SD card but its for the internal mem i think).. that reduced it a lot.
On a side note even with little apps active it consumes a lot of memory ..is that normal ?? (i have about 35Mb free that seams low, despite i close any app.
The phone isnt going slow, or things like that the freeze is sudden, and the reboots are way to often...its not a functional phone
GT -I9300
4.1.2
Baseband version 19300XXELL4
Kernel version 3.0.31-566833
Build number JZO54K.I9300XXELL4
How can we demand Samsung and Google to solve it ?
its something else i dont have an SD card, but it crashes too
there is dough an old hardware bug with some SD vendors
Hello everyone,
My firmware is :-
Android 4.1.2
The phone froze after 43h of uptime, which is pretty good compared to freezing after every 2h.
I need some info:-
which is the latest firmware for this phone(german S3 unbranded, factory unlocked)?
Back again with another update.
Sent my completely frozen phone to Samsung service center in Germany (DAT Repair GmbH)....just got it back. Had it on about 30 minutes and it has frozen 5 times. I think it is mid number 6 right now.
I am going completely ape at the moment. Two weeks without the phone, get it back, and it boots up then freezes a few minutes later. GREAT JOB GUYS!
The delivery note from the repair center translates "We have carried out a new program. Your machine now meets all specifications of the manufacturer". So, apparently freezing phones is a Samsung specification. Good to know :mad:
I've about had it with this piece of junk. Between this, and the fact that Kies has NEVER since day one worked right (detects the phone every 3-5 plug-ins....and backup has never actually completely carried out), then their service partner can't fix the thing.
I won't say I'm never buying samsung again, but I sure will be considering other phones ahead of Samsung for my future purchases. This is simply ridiculous. Not just my experience, but the fact so many others are having the same issues as well and nobody seems to be getting it fixed.
I need some info:-
I hear you Jerome10..
Which is the firmware your phone is on?
What is the latest firmware for the phone?
so I can atleast try different firmwares and post the results.
Firmware looks like ...
well not sure what firmware is, but its baseband version I9300XXELL4. Android 4.1.2.
No updates available either OTA or on Kies.
liquidsnake757
