HELP HELP HELP Finding a widet
All I can recommend is to try find the contact details of the website where you found this and ask them.
Alright,
so i have a Sony Xperia Ion from AT&T and i found this picture and want to make my phone look like it too (included in link)
Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
I found the background live wallpaper (its called Air stream live wallpaper) but i want the weather widget, clock and date widget and the bottom bar i cannot find any information!!!!
Thanks for the help!!!
Travis
Try Atom widget with this theme:
https://forums.androidcentral.com/e...tom.theme.NamuSModernTypoBlack&token=Yp-HLuM0
Then adjust the display of the widgets and icons to you liking. I think this one is it, its the closest I've found to it.
Just play around with this theme and launcher, see what you can customize, see what you cant and report back.
