Help! Icons disappeared!
Mar 3, 2020
10
Please help!
On my Galaxy Note 10+ running Android 10, I woke up this morning to find dozens of website shortcuts I had put on my home screen to be totally gone. I didnt delete them myself, there no system update, no crash, they were just... gone. I tried restoring from samsung backup which was made last night when they were all there; nothing (that actually deleted more items!). I restarted several times, nothing. I don't know what else to do. Please, does anyone know what I can do to fix this? This is extremely distressing. Have had this phone since September with no prior issues.
That is strange behavior, try locking your home screen by long pressing empty spot on home page then tap home screen settings see if it still happening
Also, which browser did you use to create those shortcuts? Any recent change or update for the browser app?
Weird, you didn't accidentally change launcher or start up in safe mode somehow... It does sound strange
Combination of Samsung Internet and Chrome. No changes or updates. It's only the shortcuts that were in folders, strangely. Both Samsung and Chrome shortcuts were affected equally.
Very strange. I found some similar reports and in some cases they were related to Power Saving mode. Did you turned this feature on or off before this problem started?
Since you seem screwed anyway why not try a factory reset and then run the last backup again
This sounds like "I'm sorry you were robbed of everything you own, but at least they won't rob you again tonight!"
DannaOgle83
