Help my Sprint Galaxy S3 is completely DEAD after flashing new ROM!!!
I have a similar problem with my s3 but when I put it into download mode it wont stay on long enough for odin to reset it to stock
<ID:0/003> Added!!
<ID:0/003> Odin v.3 engine (ID:3)..
<ID:0/003> File analysis..
<ID:0/003> SetupConnection..
<ID:0/003> Initialzation..
<ID:0/003> Get PIT for mapping..
<ID:0/003> Firmware update start..
<ID:0/003> sbl2.mbn
<ID:0/003> NAND Write Start!!
<ID:0/003> sbl3.mbn
<ID:0/003> aboot.mbn
<ID:0/003> rpm.mbn
<ID:0/003> tz.mbn
<ID:0/003> boot.img
<ID:0/003> __Xmit Write fail
<ID:0/003> XmitData Fail..
<ID:0/003> Complete(Write) operation failed.
<OSM> All threads completed. (succeed 0 / failed 1)
any suggestions?
I don't know if this will help, but Odin seems particularly sensitive to the data connection. If you're using a USB hub, use a port on the PC instead. If that's not it, try a different cable and/or USB port.
hi there.
my Android 4.1.2 XXELLA Jelly Bean on Galaxy S3 I9300 was root sometime ago-2-3 months max.
How to Root Android 4.1.2 XXELLA on Galaxy S3 I9300 | Techmell
i used info from page above( slighty difference is that i put on PDA CF-Auto-Root-m0-m0xx-gti9300.tar.md5 - PDA build I9300XXEMC2 )
i also install 3D Chain fire.(when i open this app and i "granted" permitionsthe phone DIED!!)
WONT REBOOT!
I NEED HELP TO FIX IT!!!
PLEASE SEND ME INSTRUCTIONS!!!
What version of Chainfire did you install (post a link). The first one I found in the play store says "!! For Froyo and Gingerbread ONLY. NOT COMPATIBLE with Honeycomb/Ice Cream Sandwich/Jelly Bean !!"
Can you boot into Recovery or Download mode? What you need to do to fix it depends on the answer to those questions.
By the way, you're posting a question about the international version of the phone in the Sprint forum. That's a very, very bad idea. You're likely to get advice that is intended for a Sprint phone, and will hard brick your i9300. With matters of rooting and ROMs, it is absolutely imperative that you only use ROMs and rooting files intended for your EXACT model of the phone.
I strongly urge you to repost in the forum for the international version of the phone: http://forums.androidcentral.com/samsung-galaxy-siii-i9300/
Hey can someone help me with this problem? I was installing a new rom on my galaxy s3 everything was ok it finish flashing an it says rebotting device after that never start again i buy the phone when it judt come out and it has no w
arantie
arantie
You're going to have to give us more information to go on. First, and very important: Do you have a Sprint GS3? If not, stop reading in this forum, and go to the forum for the version of the phone you have.
Second, what ROM were you trying to flash? Don't just name it, give us a link to the site where you found the ROM.
Third, can you boot into recovery or download mode? (Search for instructions, they've been posted hundreds of times.)
RichardDixon
