I installed Cyanogenmod.. didn't like it.. but I didn't have a backup.
I decided I would use a close to stock slider rom. it worked okay.
Now I thought I could fix everything by using a completely stock slider rom that I found, since I can't find a Q stock rom anywhere... and it won't connect to data, and the home/menu buttons are switched. I'm sure that'll be the least of my problems using a flip flopped rom. Anyways, if you have a Q stock rom or extremely close to stock, like maybe just bloatware removed AT THE MOST (No color or icon changes please) I would greatly appreciate the help.
