HELP PLEASE !!! Nexus 6P Will Not Boot After Flash Factory Image Using WugFresh
DLK1
625
Nexus 6P Will Not Boot After Flash Factory Image Using WugFresh. The flashing seem to go well with no errors. However, after the phone rebooted it now sits at the Google/padlock screen forever. It never get to the point of the color rotating circles. I followed NRT advice and let it run for 20 minutes, I let it go for 30 minutes. Then I booted into recovery mode and did a factory data reset. Again 30 minutes passed and still can not get past the Google/padlock screen forever. So as NRT suggested I then tried to Flash Stock + UnRoot using the Soft-Bricked/Bootloop mode. Again the same results. I went through the above process twice once using Build MDB08M and then again using Build MDB08L.
Please if someone can help me, please respond. Right now I have a $600 paper weight and no phone. PLEASE HELP !!! :(:'(:confused:
Use the full SDK to get the correct up to date adb and fastboot and flash the factory image the manual way? That's Googles answer.
I did some research last night and found this site, check site this link. I then retired for the night. This morning I will download the necessary file and try this method today. I would just like to get the latest Flash Build on and the Unlock and Root. I have done this numerous of time on the N5, using NFT and did all Kit-Kat and Lollipop builds. I thought this would go just as easy. Having a bricked $600 phone is not a good feeling at all.
you can almost never brick a nexus. its just a soft brick
Yes, soft brick. That is what I wrote in the OP however, I was in a hurry and tried to shorten thing up. I was able to follow the XDA procedure and get a working unit. :)
Now on to rooting and then a restore of Apps and Data. I am now on the latest build.
dunalfu2
