Help please? 'no sim' and mobile network option missing from menu - S6 edge
Buttercut
My S6 Edge is failing to recognise the Sim card. (aim works perfectly in another handset). I've gone into the settings menu to look at the network settings, but 'mobile networks' is now missing from the menu. Can anyone help?
Many thanks
I would try getting a new SIM card and see if that helps.
First take the Sim card out and reinstall it, if that doesn't work try what the others are saying.
Many thanks
HI,
Did you find any solution to your problem? I have the same issue and I don't know what to do! I am very confused!
