help, sd card wont mount!
jdm-skyrocket
98
13
So I have a gs2 i727 (skyrocket) from at&t, i rooted it with doomlords v3 zergrush exploit, I installed cwm recovery, then I flashed to cm7 (I placed zip file on external SD card, should I have placed zip file on internal SD?). Every thing worked great for a few hours, then out of the blue I noticed my SD card was showing up as being not mounted, it tried to mount it but it says SD card blank. Next I made sure SD card was properly inserted, cleaned the little connector on card and got the same message, SD card blank. Then i tried to format the SD card, still says card is blank. Then I used a backup to get my phone back to stock, I used Odin to flash the stock recovery back on to phone, and tried to remount the card, same message SD card blank....?!?! Grrr!!! in not a noob with rooting, flashing but I'm no expert either, can anyone please help me get my SD card to mount again? Any ideas would be greatly appreciated! Thanks!!
Anybody ever had this issue? Guess I just need to test the SD card on another phone and see if card is dead.
careerzoneacademy
