HELP! Stuck on Fastboot
alvingaoat
I have an LG G2 AT&T D800.
After I rooted my phone successfully, I also flash a custom recovery successfully.
After I did that, I wipe out my data / cache.
And i tried to install a ROM and Google Apps.
I rebooted my phone and I'm stuck with " Fast boot mode started "
Fastboot mode started
udc.start()
-- reset --
-- port change --
-- reset --
-- port change --
Fastboot: processing commands
I had download mode working but i accidentally made it stop working after i did CMS88168 steps from this page.
http://forum.xda-developers.com/show....php?t=2477595
Now I don't have my download mode to work and I have no clue on how to fix my phone.
Please help.
I tried installing every USB driver but errors keeps on showing up.
LG suite can't connect to to it.
LG support tool can't connect to it.
I tried CMD and see put abd devices, nothing shows up.
So far I can reboot, flash .img files onto the devices using fastboot.exe with CMD.
Thats about all that i can do. And nothing works. :'(
I think I had a similar issue to this, if you have a custom recovery (if not load it via fastboot) turn the phone off wait for it to completely turn off then hold the power button and volume down key, when LG logo appears let go then quickly hold them again it will go into hard reset option then press power button twice and it will boot into recovery. Then if your ROM and Gapps are still there, factory reset, then install ROM and Gapps and it should boot up. My phone just kept spinning on boot logo with 2 ROMs that i tried, the issue was FACTORY RESET from recovery.
TechPulse
