Help with themes and RubiX
dwt10
80
So I installed Rubix 1.0 Focused on my DX and I really love the 928droids bgx theme. So i installed that by renaming it update.zip. after a fail bootup I did a factory reset which is what you should do when you get the startup animation. Now I'm confused. I check System Info, and it doesnt say rubix. My bootup animation is rubix. and all my preinstalled apps are back. does anyone know a proper way to have both the theme and rubix installed? please reply soon because I need that extra speed :P
i could not get 928BGX to work with rubix. thats one reason i went back to fly x . But there are themes that work with rubix . you have to google to find out which ones are compatible with rubix.
RichardLevi
