Help
johnb0072
65
I just had to do a hard reset to fix an issue and somehow when I restarted I have all contacts in my list 791 when it should be around 200 I've been trying things for hours and can't figure this out.
I do but I haven't turned it on yet...this is all email addresses all Facebook all Gmail its unreal I've cleared the data so its empty now I know I'm just messing up a setting somewhere but jeez.
Usually it prompts you if you want it to bring that stuff in.
Update...so I d/l go contacts...delete the duplicates then export to the SD...go into people and import the file..still should've been easier.
There are settings that allow you to control which contacts are displayed. My Contacts, All Contacts, Groups, etc.
I actually had to just unsync google for now I spent 2 hours in sprint today and got about halfway done. I've got go contacts working right and on stock its down to 400 something so I'm making progress. Thanks
EricH
